How to Build a Battery Back up for the Blower?
Srbenda
Burning Hunk
117
PA Horse Country
My insert has a 8amp, 115v, 60hz blower motor, and I want to build a relatively small backup power supply for this motor.
I have zero electrical engineering knowledge, so how do I calculate how much battery power I need to run the motor for approximately 8 hours?
I would like to have a setup that would keep the battery on a charger, and during a power outage would be moved to the blower motor with an inverter.
Any help?
8amps*110v=880watts.
You'll need an 880watt inverter, probably more like 1000 because it's a motor and takes a startup surge load.
Then you just need to pick enough batteries to to run 880watts for your specified period of time.
Is that what the motor is rated at or have you ammetered it out and find it's running load? Running load is probably a bit less than rated. But you never know.
If your going to keep the batteries in the house, you'd need nice sealed batteries, like Optima's. The biggest deep cycle (blue top) optima they make is 75 amp-hours (broken link removed to http://www.optimabatteries.com/optima_products/bluetop/specs.php)
Meaning, it'll run 75amp load for 1 hour at 12v.That's 900 watts for 1 hour. FOr your situation, inverters are usually only 80% efficient at converting DC to AC power. So your actually wattage for an hour is 720. So you'd probably need 2 Optima D31's to really run your motor for an hour or slightly more.
Then your going to have to charge and keep charged those batteries, so you can either get an inverter with a built in charger. Or have a separate battery charger and keep them topped off at least once a month.
In all your costs involved would be something like:
2 Optima D31's (approx $200/each): $400
1000watt inverter : $120
or 1000watter inverter/10amp charger: $200
misc 8 gauge wiring : $20
So your in for $520 at a minimum and possibly more if you don't already have some other means to charge batteries and alot more if you want to run it for more than an hour (you'd need 2 batt's for every hour of operation, roughly).
I supposed you could disassemble the fan motor unit, because it'll have a giant AC to DC converter built into it (most all small motors run on DC anyway), if you wired the motor direct to the battery, you could not lose the 20% both ways and lose the cost of the inverter, so effectively a 40% gain on the system. But then you'd have to wire in a switch to be able to run it on normal AC.
My advice, buy a small gas Generator, far more useful for other things and less maintenance.
Thats a lot of power to ask from a battery or several batteries.
8amp @ 115volts is 920 watts, now thw actual draw may be less than that.
To get 920 watts out of a 12 volt battery is 76 amps. Thats a lot of current for 8 hours.
If you insist on battery backup higher voltage will reduce the current load. 2 12 volt batteries in series (24 volt) would cut the current in half, 3 (36 volt) would only need 1/3 the current (25 amps) but the appropriate inverter would be required
A small generator might be a better solution. 1kw or 1.5kw.... Or just be happy with the radiated heat and live without the blower if the electric is out
+1 to what 73blazer said, he typed it faster than me :lol:
I think the real issue is that 8amps. That seems really high for an insert blower. I bet if you amped it out it's really only pulling 3 or 4. But, you just don't know unless you put a meter on it.
STill, if it was 4 amps, those 2 giant optima's would only run it for 2 hours or so. Still $520 for 2 hours runtime, plus charging (inverters w/built in chargers cost alot more).
I think Generator is best route!
8 amps is a hell of a draw from a blower. Are you sure that's not .8 Amps? With that kind of fan you'd have to tie down the furniture.
looks like .8 to me
Yea instead of trying for 1000 watts you only need to worry about 100 watts
If you did go with a generator I highly recommend the Honda EU series. I have a couple EU2000iA's. They will run nearly 10 hours on a gallon of gas at 1/4 load.
I also have some 6 gallon marine tanks so I could run it up to 70 hours straight if needed.
You could prolly buy a few hundred or 1KW UPS for a couple of hundred bucks
even with a generator, you might want to protect the stoves circuit board from voltage and hz variants from the generator with a UPS.
That's the route I'd suggest - watch the sale fliers or the net. They come up periodically from office supply stores etc. Off brand UPS systems etc sometimes for amazingly low prices. With the UPS you will get the automatic failover as well (a bit harder to wire in your home made solution). Now the question is how long do you want to be able to run it for? I would think that if you get 30-60 minutes out of it you are fine, any longer than that go hook up the generator that I think you said you already have, right?
If you go with a UPS make sure you get the right one as some of those do not like to run motors.
Agreed. You would definitely want to utilize one of the inverter generators from Honda, Yamaha, Kipor, etc.
I would never use a standard square wave generator with electronics.
Not sure I understand what you are saying , you are not going to have a square wave with a motor driven gen.
I should rephrase... it is actually a squarish wave in the cheaper non-inverter based generators versus a pure sine wave in an inverter based generator.
I don't claim to be an expert but that is what I am told.
The Hz difference alone will make a PC clock skew fairly quickly.
A motor driven gen. puts out a very good sine wave not squarish at all so you may be mixing things up a little.
I may have been thinking of an old 12V inverter that did a square wave but isn't the sine wave in a non-invertor based generator called a "modified sine wave"?
I find that I am able to power up full size refrigerators and freezers with my EU2000i that choked my old 1850 Coleman Powermate.
[I apologize for taking this somewhat off topic]
Sorry about the hyjack also , this site can explain it better than I can if you want to take a peek.
(broken link removed to http://bellsouthpwp.net/j/o/johngd/files/rv/inverter_generator.pdf)
That's only .8 amps. A small computer UPS is the easiest method. Of course, this all depends on how long of a backup you need.
