I'd have to charge $1000 a cord to make it worth my while as my property is in a small valley, in a larger valley. Half the land is across the creek (steep ravine) and pretty much inaccessible except on foot for 10 months out of the year. Lots of deadfall up off the ground but the logistics of getting it out of there are not great.I can't bother to start my chainsaw for $75/cord
Id just run space heaters at that point. Far less expensive.I was watching the local news in southern NH, they were interviewing a legit firewood dealer planning on selling 2000 cords this year. He looked like they had a lot of inventory in the background. They claim the phone is ringing off the hook for deliveries and that the going rate was $500 delivered (note a cord in Mass and southern NH is full cord 4x4x8 not a face cord. The weather just changed from a warm spell for the first two weeks of November (70 F on Saturday) to a forecast week of colder than normal temps. I guess its time for us "ants" to sit back and watch the "grasshoppers" panic![]()
It dries quick, but burns just as quick too. We burned slab wood for two years when I couldn't scrounge enough. It weemed like we were constantly throwing wood in the stove.Unfortunately, we didn't decide to get an insert until around August. I had a good supply of wood in years past, but we gave most of it to a friend that heated with wood versus letting it rot. I guestimate that I have about 1/2 cord burnable now. Close to .75 cord of Oak that was split and stacked in August (unavailable) and close to a cord of dead ash that has been split and stacked Sept - Oct. That is in various states, checked two splits today, one was 16% the other was 35%.
A local MFG of RR and Landscape Ties sells slabwood for $75 a bundled cord. Supposedly seasoned at least 8 months of various species. Problem is, the bundles weight 4 to 5000 lbs. I don't have access to a big enough truck. They do sell slabs from bundles that broke apart for $40 as much as you can load. Going to try to get some tomorrow (renting flatbed pickup) Hope that it is dry enough to burn and it can get me through.
Our rate here is 10.5 cents/kw, so the breakeven point is around $375-380/cord (for dry wood).A cord of Madrone is about 30.9 million btus. 1kw is 3412 btus. So there's about 9050kw in a cord of Madrone. Assume 75% efficiency for the stove and 100% for the space heater. That leaves about 6800kw of heat from that cord.
At $500/cord, electricity would have to cost less than 13.6 cents/kw for the space heater to cost less. I know of some places in the pacific northwest that have rates lower than that. It's more like 2-3x here but we have expensive rates.
CT’s supply rate just increased from 12.1 kw/hr to 24.2 kw/hr Effective Jan 1. Coming soon everywhere. Wood will continue to be the cheapest way to heat.Our rate here is 10.5 cents/kw, so the breakeven point is around $375-380/cord (for dry wood).
Thankfully we cut our own.
I live about 30 mins away from you and heat my 1700 sq ft 2 story gambrel cape entirely with wood. We actually don't even own a furnace just a heat pump. It's a classic 80s closed floor plan (something we're saving $ to improve. Stove is on the 1st floor in the room with the stairwell so heating upstairs is not an issue. I just use one fan to get convection started down the hallway to the kitchen and dining room and the rest happens naturally.I agree, it's difficult to calculate and normalize. I've been trying to prevent my heat from turning on at all when burning the wood. I have a 2-story colonial, 2100sqft, not including a finished basement. Three heating zones, stove is on the main/first floor. The first floor zone never calls for heat if the stove is running. The basement I keep at a lower temp, plus the thermostat is near the boiler so reads artificially high anyway. Therefore the challenge becomes the 2nd floor. I've experimented with ceiling fans but I'm finding I get the best results (I think) without any fans and just allowing natural convection to do it's thing. It was pretty cold outside here for a few days (20F yesterday morning) and my upstairs only had a brief (10min) call for heat at about 5:30AM (scheduled set temp changes from 65F to 67F). I'm ok with that. Once I reloaded the stove, upstairs got up to 69F pretty quickly.
I too had MassSave come out when we bought our place in 2015. I have a walk-up attic so I opted not for the blown-in, but they did insulate the tops of all the walls with that spray foam stuff. They also made this 'box' out of that foil-sided insulating board stuff to cover over where the walk-up fold-up attic stairs go. That thing used to pour cold air! So much so you'd get a chill walking under it. The windows were trash so we had them all replaced. I agree, it's things like this which can make all the difference. I went around fixing up my door jamb insulation and adjusting the latch depths too.I live about 30 mins away from you and heat my 1700 sq ft 2 story gambrel cape entirely with wood. We actually don't even own a furnace just a heat pump. It's a classic 80s closed floor plan (something we're saving $ to improve. Stove is on the 1st floor in the room with the stairwell so heating upstairs is not an issue. I just use one fan to get convection started down the hallway to the kitchen and dining room and the rest happens naturally.
On a normal 20 degree winter day I'd say the living room is 75, tv room 70, upstairs 70, and the kitchen/dining room 65 all give or take a few degrees. Our backup heat only comes on when it gets close to 0 outside for a day or two and it might pop on at 5 am for an hour. I could wake up to reload early but most times I just let it do it's thing.
Mass Save was out and blew 2 ft of insulation in the attic right before we bought the place and added the stove. I'm sure it's the reason I get away with only using the stove. The windows are all original and those are the next upgrade on the list, but, I suspect those will be a one or two a year thing for a while.
