Hello!
I am having an issue with my Englander 25-pdv stove lighting the pelletes. When I go to start up the stove it *should* feed a certain amount of pellets and then the igniter will heat up and start the process. The igniter never kicks on and the fire never starts. If I start the fire manually {fire gel} everything runs fine.
I called Englander and got a replacement igniter and swapped it out with the old one... however the problem still remains. I did doublecheck all of the connections on the mainboard and everything has been cleaned {including around the igniter
} I will call them again next week but I was wondering if anyone might have any insight of what is going on.
While I am at it...I have one other question involving daily/weekly cleaning. During the course of the week we are running the stove almost 24/7. We will stop it for an 1/2 hour or so twice a day and scoop ashes to the side. About every three or four days I will shut it down for a few hours {complete cooldown} and vacuum out the ashes. I will also pull the plate from behind the burn box and vacuum everything that I can get to {including plate}. About once a month I will open the cleanout t on the vent pipe and vacuum out what I can. This spring I will completely tear the stove down and clean it well. I am just wondering... am I missing anything that I should be cleaning on a more regular basis? Once again..any insight would be appreciated
Thanks as always...
~J
Stoves..
Englander 25-pdv in the house
GloKing P100f in the shop ..10 degrees outside... 75 inside. Gotta love it
6 tons of pellets for this year... 2 down 4 to go
Thanks as always...
~J
Stoves..
