Just thought of one quick addendum to Goose's initial post about the good idea of doing a pre-season check every year (I don't always get to it depending on other demands on time- but then kick myself for it later when I have to check something in the cold if it acts up)--
-- I do not know the layout in detail on the Ariens, but, regarding the idea of emptying the gas and tipping it up to open and check the drivetrain-- with some yard equipment (and it varies not only by make of equipment but make and model of engine, which can vary even on the same model of equipment)-- I've seen some yard equipment where the engine's crankcase breather-- which is connected by a tube to the air intake-- will allow crankcase oil to run into the carburetor if the engine is tipped a certain way. Again- whether that happens, and what such " tipped a certain way" that'll do it is going to vary a lot by make, model, and even year. But-- it is NO fun if it happens to you; if it happens, you may end up with a spark plug fouled by oil, or a gooed up carbuetor (which may act up later on due to the goo). Even if you don't have those consequences, the engine may be hard to start, and you'll get a billowing cloud of oil smoke when you start it.
So- my advice with any small engine where you're going to need to tilt it to any position that is different from its usual operating orientation is to drain the oil before you tip it. Most people don't change (or check...) their aircooled engines' oil as often as might be wise, anyway, and if you are doing an annual pre-winter check on your snowblower, it wouldn't be a bad time to give it fresh oil, too.
I am a fan of synthetic oil in winter equipment, as it does not get as thick- which can make starting easier, and I figure that it also makes its way into the various engine parts faster since it is not so thick (a huge portion of engine wear occurs at start). No need for "Mobil 1" or pricey stuff-- I just get the large retailers' house brand synthetic oil-- or I sometimes get the 5 Qt. FoMoCo synthetic blend 5w20 in the red jug (pretty economical stuff) on the same shelf. Lubricant is less expensive than parts...
