Smoke in corn hopper
SusieqPatriot
3
Ohio
Hello, I have been using our Snow Flame 2100 corn stove since 2001. I noticed a small amount smoke rising from the corn hopper when refilling a couple years ago. It seems to be getting worse. I can see and smell the smoke rising when hopper lid is open. I'm wondering if over time, the auger has worn and allowing smoke to seep around it. Or is there a seal that may have gone bad? What should I be looking for? Thank you!
I just took the chimney pipe apart and cleaned it out. I used my drier vent clean-out brushes and extensions attached to my drill. Worked well. It did have more build up than I expected. now wrestling to get the inner flexible pipe back in place. I can't get a grip on it with the outer black pipe around it. I think the outer pipe is just to cover the inner silver flex pipe?
Reactions: Ssyko
What about inside the stove? From the fire box to the chimney?
It sounds like the stove is struggling for combustion. Clean the combustion fan
and all the ash traps in the stove
