A few months back I posted about adding a secondary air control to my Morso stove. I'm now discovering yet another benefit of this.
Actually, I should say "rediscovering", because it's basically what we did with our "airtight" stoves of the 80's and what the oldtimers did when they talk about banking their fire overnight.
By completely shutting off the secondary air supply, I have easily doubled the burn time of this stove. (By "burn time" I mean, the time between the end of the last fire's flaming phase and when I can easily revive a new fire simply by adding wood on top of the bed of coals.)
I always try to arrange my burning so the flames are dying out right around my bedtime. Last year, I would close the primary air supply, and wake up to find a cold stove with nothing but ashes on the grate. This year, I leave the primary supply just slightly open, completely close off the secondary, and I wake up to find the stove at 150-175 degrees with a bed of coals, mostly black but some still alive. A couple minutes of exposure to full primary air livens the coal bed enough to ignite a new load without building a fire from scratch.
The last two evenings, this period was 9.5 hours. Last night's flames died around 10pm and at 7:30 this morning it came back to life.
Just another benefit of adding a secondary air control to your stove, if it doesn't have one already (most don't.)
I'll also add, in normal operation, I have the secondary air set at about 60-70% open. Under most conditions, the amount of secondary air supplied is MUCH greater than needed.
The size and amount of wood the Jotul takes would be considered large kindling by you, I'm sure!
