First Post here. (2-21-2011 update excerpt pasted below)
Have 4 questions listed below and a Cat one at the very end.
1. What 5 non-cat large box (= or > 3 cu ft) wood stoves actually burn more than 8-hrs on seasoned hard wood after getting a good bed of coals before going to bed? *** I'm talking only about stove temperatures that actually can keep a fairly tight 1,000 sq ft room (open floor plan) at 70F when outside temps are 5F. That's 70F in the room by the end of the burn.***
2.. What about a 2,000 q ft room (open floor plan)?
3. Are there any non-cat EPA approved boxes that exceed 4 cu ft? 5 cu ft?
4. Can you re-prioritize those stoves based ONLY in the quality of their construction for longevity (low maintenance issues after being used daily for the main heat source)?
********Please state if you are a dealer/salesman or in any way associated with a dealer/salesman and/or manufacturer in the beginning of your replies. Thank you.**********
Background/comments:
I started reading all the posts I could about burn lengths, etc before my eyes glazed over. All the posts are very interesting, but nothing really jumps out as the smoking gun to help lead the way on my next purchase.
This new stove will be a basement stove that I hope to use as the primary heat source instead of my LP furnace. The 3-yr old house/cabin is 2400 sq ft and sits at 9,000 ft above sea level and is totally off the grid. I really bought the LP furnace as an emergency back-up and quick heat in the morning. I started to look at coal as an option, but backed off that path. I am still somewhat interested in combo boxes (add-on furnaces/stoves) like the Fire Chief and Energy King, but there are drawbacks for my application; thus, back to free standing wood stoves.
I have a Hearthstone Phoenix upstairs and am disappointed in the short burn times of about 4 to 6 hrs (high/ low settings). It has a vacu stack and uses outside air. I enjoy the stove otherwise, but still think it was a little pricey even though I got it on sale for $1,750 before taxes (stove only).
Basically Im looking for a solid work horse this time.
As for Cat stoves and their followers:
Ive only read about the Blaze King's King 1107. Ive never used a Cat stove and shy about switching. When I did look at a King I was bothered by the metal used in its construction: It was the thinnest I've seen. Actually I only physically touched the Princess 1006 and assumed the metal used would be the same in the King 1107. Ive also physically seen/touched the Harmon TL300, Quadra-Fire 5700, PE Summit, Regency F2400 (medium box, but would buy the large box) and the New Englander NC30. and read about the Naploean 1900. All of the stoves that I touched had thicker steel used in their construction than Blaze King. Some by a lot (quality/longevity issues).
FWIW.... I Also noticed the cheaper stoves had a smaller inner fire box/chamber than what they advertised when I actually measured them one by almost 1 cu ft.... FWIW. The King's Princess advertise a 2.8cu ft box, but the inner chamber is actually 2.52 cu ft; I assume the King 1107 would be a little smaller than advertised as well... but still close. The thinner steel, cat technology and the very very high price make me weary of the King. Any comments from King/Cat users?
Thanks in advance,
Solar+Wood
2-21-2011 ****UPDATE*** See post #43 to see all of the post...
Someone here has probably already done this…. but what they hay anyway.
AVG BTU burns over the course of 8hrs. Based on a formula noted below.
I assume some will have issues with it, so have at it smile
It is my first draft and could use some help if I have something wrong.
so…Help me create a fair comparison since the industry has not.
Listed in order by size of firebox (smallest to largest)
Woodstock Fireview... 31,530 AVG BTUs for 8hr burn..(72% eff)... 2.18cu ft
Herthstone Phoenix... 33,145….....................(75% eff)... 2.2cu ft
Regency 2400........... 35,576….....................(77% eff)... 2.3cu ft
BKK Princess (CAT)... 46,403….....................(82.5% eff). 2.8cu ft
Regency 3100…......... 43,924….....................(75.4% eff). 2.9cu ft
Harmon TL300…........ 45,801….....................(76% eff)... 3.0cu ft
PE Summit…............. 48,392….....................(80.3% eff). 3.0cu ft
Hearthtone Mansfield..49,754….....................(77.4% eff). 3.2cu ft
Everzone 3.4….......... 53,273….....................(78% eff)... 3.4cu ft
QuadraFire 5700…..... 52,518….....................(76% eff)... 3.44cu ft
Englander 30-NC…..... 53,434….....................(76% eff)... 3.5cu ft
BKK King 1107 (CAT). 71,594….....................(82.5% eff). 4.32cu ft
Buck 91 (CAT)........... 76,013….....................(86% eff)... 4.4cu ft
Buck 94-NC…............. 64,523….....................(73% eff)... 4.4cu ft
Add your own box by using the formula below…. Enjoy!
Look at the note below about the two Buck stoves for CAT vs. NC comparison…. interesting.
*********See post #43 to see all of the post not just this excerpt (Formula, etc)...**********
Thanks in advance,
Solar+Wood
