I have the removable plate on the front of the stove below the bottom of door opening, which has holes that align with the holes in the square welded air intake on the firebox. Sometimes it warps with different stove temps as others have noticed. Once I removed this plate and noticed a few holes in the matching welded firebox clogged with ash. As I touched the ash, it fell into the square welded air intake - but unclogged the holes. I assume ash will build up in there.
So question is this - do others have issues with these holes getting clogged?? How do I get the ash out of the welded assembly?? Maybe vacuum thru the large primary hole on bottom once in a while?? Is this not really a concern??
As always, thanks for your input!!
p.s. - as long as I am asking questions......sorry, T6 newbie here....... Sometimes when I load the wood, I load it right up against the baffle - even if it touches and needs a little push to get in (sliding along baffle bottom) but definitly not forcing it in. Is this ok to do???
