Are you setting the pot on the stove directly or a diffuser ( I believe that's what it's called)My steam pot. 20 quart commercial cooking pot. Fill it once every 3/4 days. Easy for the 3 off days, but you really have to have both hands to get it filled and back to the stove on the 4th day.
we fill it out of gallon milk jugs. easier to carry
That's exactly what the wife does......makes it really easy.MWN, take a tip from bogydave...
Leave the pot in place, use a smaller, more convenient container to pour in a gallon (or a quart) or so of water as needed from time to time...no more toting that sucker completely full from sink to stove.
I gotta be a tough guy and lug the pot over to the sink and fill 'er up........
do a search on vapor loss once, you'll see just how much vapor you lose in your house in the winter. 6 or 7 gallons over the course of 3 to 4 days is nothing........I do this and STILL have trouble keeping the house in the 30-35% range. Optimal moisture in your home should be around 45%.I can't imagine putting 6-7 gals of water in the air can be healthy?! Be carful for mold and condinsation in your walls.
My house stays around 25-30% in the winter which is fine.
I do get a pile of minerals at the bottom of the pan. It's amazing how they crystallize in there. No nosebleeds here, but I do know that in the dead of winter you can let the bag of chips or a tub of popcorn open on the counter overnight and it don't go stale....I gave up on pots/steamers. Not only did I still need a humidifier to keep the nosebleeds at bay, when it boils dry (yeah, I couldn't get the wife to be proactive about filling it) it spews little white balls of minerals everywhere! And actually, I don't notice a difference in how much the humidifier runs.
I do get a pile of minerals at the bottom of the pan. It's amazing how they crystallize in there. No nosebleeds here, but I do know that in the dead of winter you can let the bag of chips or a tub of popcorn open on the counter overnight and it don't go stale....![]()
You what they say about brilliant minds buddy...........That's the SAME pot I have, MWN! I love having that big pot on the stove, I modified the top sheild on my Napoleon 1900P late last summer so the pot could sit right on the stovetop, and MAN what a difference! Lots of moisture comes off of that thing.
Most musical instruments require a minimum of 40% humidityI can't imagine putting 6-7 gals of water in the air can be healthy?! Be carful for mold and condinsation in your walls.
Vinegar!You what they say about brilliant minds buddy...........
I take a wire brush to mine every 2 weeks or so. I ruined a smaller, more expensivepot last year, Calphalon or something like that. Minerals are rampant in the water here. Very hard.
I wouldn't care if my windows fogged up and iced up...your furniture is going to pay and worse your bodies pay for being dry!Like anything else, there are variables
When your area is a cold "arctic" area , the humidity recommendations change from what is the "norm" for most areas.
If we had 45% moisture inside here, our windows would fog & ice up on the inside.
Optimal range here is 25 - 30%,
When we go below zero, my windows start icing up in the corners & we reduce the humidity setting to 20% or less.
10°f now & have 24% humidity, perfect for today's temperature.
With the wood stove running & it drawing in dry cold outside air, we go thru 3 to 4 gallons / day easy.
Humidifiers came with basically the same chart for Alaska & had a good explanation.
Chart:
