29 Years and a big screw up - NEED HELP
That really doesn't look bad at all. The crosshatching from the cylinder's factory honing is still very obvious so I'd say the cylinder was in great shape before this little misadventure. I don't see any scoring, just a fairly small amount of aluminum transfer which would've been easy to clean up. That bore plating is very hard, so I doubt you did any damage with handheld emery cloth. Also, damage below the exhaust port (where most of the transfer seems to have been) wouldn't affect compression. I think it's going to be fine.
Some little tips that might help:
Buy new OEM clips for the wrist pin. They're better than even the Meteor clips, and are cheap. Don't try to reuse the originals, even if they seem to be okay. Buy three, in case you spoil or lose one.
While you're at it, buy a new base gasket.
ereplacementparts is likely to be a good source for both clips and gasket.
Rinse the heck out of that cylinder, to be sure you've eliminated any grit remaining from the emery cloth. It's not ferrous, it won't rust. Careful with harsh detergents, though; a brief spritz with simple green as a degreaser won't hurt it, but don't let anything like that remain on the surface for long.
Muster an extra measure of finesse when installing the ring onto the piston. It's easy to slip and scratch the piston surface.
There will be a little arrow stamped on top of the piston. It should point towards the exhaust.
The openings on the retaining clips should point either straight up or straight down, i.e. in line with the stroke of the piston. If it is perpendicular to the stroke of the piston then there's a chance that its own inertia could cause it to flex and pop loose at high RPM's, which would likely lead to catastrophic failure.
Some people put the saw inside of a big clear plastic bag and reach inside of that to install the clips. If a clip pops out of place and goes flying, the bag saves you from hunting around the room trying to find it.
A simple piston ring compressor(broken link removed to http://www.ebay.com/itm/STIHL-RING-COMPRESSER-026-031-032-036-038-041-045-056-044-046-064-066-084-088-/351118895811?pt=LH_DefaultDomain_0&hash=item51c0512ac3)would make reassembly easier, but is not absolutely necessary. Also, see the (broken link removed to http://www.ebay.com/itm/New-502507001-Piston-Stop-Ring-Compressor-Stihl-Husqvarna-Homelite-Tool-Kit-/130617654291?pt=LH_DefaultDomain_0&hash=item1e696b3c13) at the bottom of the main pic on this listing? That spans the crankcase opening (slot is for the connecting rod) and supports the piston while you negotiate the bottom of the cylinder over the ring. You can make an equivalent tool by simply cutting a slot in a piece of scrap wood.
Tightening torque for the cylinder is 8 to 10 Nm, or 70-88 inch pounds. You probably don't have a tiny torque wrench, but keep in mind that those little cylinder bolts should be quite tight, and tightened evenly. After you think you've got them all tightened down, go around and snug them all up again.
Let us know how it all goes! I think you and the saw are going to be just fine.
Oh, and if the intake is held to the cylinder with a plastic snap-together hose clamp kind of thing, you should take this opportunity to replace that assembly with the updated version which has a metal clamp band. The all-plastic ones are a common failure point; if the clamp breaks then an air leak develops and puts you right back where you are now.
Reactions: D8Chumley
Nope, but it's a related part. I'm referring to the "partition wall intake" linked in my post, and in any case there's no point buying aftermarket when the OEM part is cheaper.
Thanks! Just checking! I'll keep you posted on how the rebuild goes.
I don't know if they have all these other parts you are looking for, and I know I'm late to the conversation, but I always feel comfortable buying from Baileys Online. They probably have the piston kit you got for $40 bucks. I've never ordered from the hlsproparts website y'all are talking about, so don't take my recommendation as indicating that baileys is better. I don't know!
Good luck with the rebuild!
Well, I finally got the 346xp running again! It is a scream machine!!!. I was able to lightly sand the cylinder with emery cloth to remove the scoring just underneath the down stroke on the muffler side. I installed a Meteor piston and ring (42mm). I also installed a new partition wall intake. The most difficult part was putting the carburetor back on the saw....I don't cuss but I came close :mad:. Thanks all for your help! Hopefully I won't make the stupid mistake of not checking my gas and oil mixture ever again!
Reactions: Danno77 and Jon1270
That's great to hear. Congrats!
I wouldn't put anything but OEM stuff....but that's just me. There's some real crap out there.
Yes there is some real crap out there, but the Meteor piston is top shelf, along with Caber piston ring(s). Glad the saw is back in service, and yes re-installing the carb is a PITA.
Reactions: Danno77
I did the research on the best part and Meteor is a 'top level' replacement part. And....your right, there is a lot of junk out there!
Reactions: Danno77
Hello all, I have been running a chainsaw for a long time but yesterday I experienced my first big screw up. My primary go-to saw is a Husqvarna 346xp which has been an incredible saw. I accidentally put gas in the saw without any oil....not paying attention....ARGH!!! The saw ran for about 3 minutes and then just stalled. The piston is not froze up. I took out the fuel and put in a gas/oil mix. I also took out the spark plug, added a little oil to the cylinder, and let the saw cool. After cooling, the saw will start for about one second and then stop. Any ideas on how to fix my problem? If a rebuild is necessary, the type of rebuild kit I should get? I've never rebuilt a saw so any suggestions would be appreciated. THANKS!
Just a suggestion for preventing this in the future. Get a gas can that is different that all the other gas cans you use and use ONLY that can for your saw(s). I never add gas to this can without first adding oil before adding any gas. I figure worst case I'd put gas in my saw that has too much oil which would not be catastrophic.
After seeing several straight gassed saws over the years this is what I have gone to and it prevents me from making a stupid mistake.
Just cut up a cord of hemlock for next season (2015 - 2016). The saw ran perfect! Thanks all!
Reactions: Jon1270 and Danno77
Not only do you have your saw back, but you know a lot more about it. Ain't tinkering great?
Reactions: toddnic
Nice Job. I love nice endings.
It would've been nicer if he'd just given up and sent the saw to me, but this is a decent consolation prize.
