25 PDVC Englander settings
Usually 6-4-1
Hello
6-4-1 is the Factory default for Max heat.
If you want to save pellets I always recommend
4-6-1
Not much difference in heat either. :)
Hello
4-6-1
Thanks for that info. I'm hoping those setting allow me to turn the flame down. Right now it is raging and too hot, even set on 1-1. Suggestions?
Check what mode your stove is set to. Should be set to D. Unplug, wait 30 seconds, plug back in and immediately press both lower buttons (up and down). There should be a letter there and for your stove, that should be D.
Eric
