EWILT said:Could there be the chance that if you run your fan on 9 and your heat on say 3, you are actually cooling the heated air? Just a question as I'm trying to get the most heat out of every pellet burned.
Eric
I started using a t-stat on mine this month, and since the weather hasn't been that cold the stove usually idles at a feed rate of one and the fan on nine. The air coming out of the stove is still very warm.
!! the gate in the hopper is closed as far as it will go. no un burned pellets either. What a pc of crap
