25-ep stove Ash build-up
Hi:
Thanks, everyone for the advice on the vent, I have now fixed that. Now a new issue, how do I calm this thing down? I am running the low end setting on 1-4-1. Running off a thermostat on high-low. Heat and blower settings are both on 4.
The stove is kicking out a ton of heat even in though it is running in the low range, too much heat. I guess the easy answer is to run it in off-on mode, but I don't want to cycle it off.
So how do I get it to calm down in low settings? (Using Cubex pellets).
Thanks
Julian
Hi:
Thanks
Julian
Maybe I missed something, but what about just turning the heat setting down?
It should only burn on the 4 settings when it's calling for heat in hi/lo mode and then kick down to low once it's satisfied...It looks like it's still too warm/too much heat when it's in low.
My 25 ep does something similar. My settings are 1, 4, 1, no thermostat. When my heat setting is on 3 the stove cranks heat and then my blower goes to max.
