I had a Taco 007 as my main circulator.  The motor was hotter than the water running through it so I changed it out thinking that the motor must be bad...now the new replacement is just as hot as the old one.  The motor is hot enough that I can't hold on to it.  It gets to this temp about 20 minutes after you fire up the system.  I have another Taco 007 hooked up directly to an electrical outlet on the primary loop that is just as hot....is this normal???  The flip side is that it's helping to heat the water
