arnermd
Sounds like a good approach.... will try that next time.Yeah, it can be tempting to close the damper early if the load really takes off. I usually set myself a timer for 8 minutes and if the flue temp starts to redline before the timer is up I will close the damper but then re open it once the flue temp drops. I find the extra time with the bypass open helps the load catch and avoid overfiring the cat.
When I reloaded, the damper was open (secondary bypassed). My point was that with that much air coming in some goes out through the secondary. Most goes out the bypass damper of course. I have lifted the griddle with the cat engaged before..... definitely has an effect!Also.. you mentioned opening the griddle with the bypass closed..? I wouldn't do that
![[Hearth.com] 2021/22 VC Owner thread [Hearth.com] 2021/22 VC Owner thread](https://www.hearth.com/talk/data/attachments/291/291854-f9b651308eab89ae170ec5cad95a01e6.jpg?hash=dOOpeT067q)
![[Hearth.com] 2021/22 VC Owner thread [Hearth.com] 2021/22 VC Owner thread](https://www.hearth.com/talk/data/attachments/291/291855-4c48d1412ba186474f3f43770b5f1896.jpg?hash=3hMQXOsQO-)
![[Hearth.com] 2021/22 VC Owner thread [Hearth.com] 2021/22 VC Owner thread](https://www.hearth.com/talk/data/attachments/291/291856-9959c47935972af81fb2ac18b7283941.jpg?hash=X8x9m4kkmE)
![[Hearth.com] 2021/22 VC Owner thread [Hearth.com] 2021/22 VC Owner thread](https://www.hearth.com/talk/data/attachments/291/291857-0a456143680202c6f59fdf2f2ccbf325.jpg?hash=sccWvjWzsV)
