Hi. I picked up a very nice princess 1006, 2nd hand but in nearly perfect condition. The cat is in perfect condition (rectangular style) but it still produces smoke a fair bit even once at a good burning temp. I burn dry fir. What is a proper activation temp? I don't know if the themometer is calibrated correctly. I don't ever see the cat glow read unless it is REAL hot. It fits snug, has no cracks, has no build up etc. I can get a good long burn no problem, and I'm very impressed with the stove, compared to the 80's BK it replaced, but I did expect the smoke to be almost non existant
I have a box full of perfect looking but dead cats. They wear out in just 1200 hours and don’t look any different when they are worn out. New cats are 209$ shipped from Amazon. It’s a wear item.
Just circling back on this ...
The dealer didn't really have any suggestion to offer, beyond what came up here: "pry the washer off." It probably didn't help that my wife took the call, triggering the usual faint insinuation that this was gender-based operator error.
Anyway, out of patience, she and my son decided to force the issue. That required using a thin blade to get some leverage on the washer. The thing is, it's not a washer. It's a "round base weld nut" - i.e. it's threaded, but with no way to get any purchase to hold it in place while turning the Allen bolt. Once the flange was flared a bit, at some cost to the blade, they were able to get vice grips on it and remove it, with the help of a little penetrating oil.
Once we replace the part, we'll be back in business. I don't think I'll use the stock steel one though - I'll find something in stainless, and maybe add some high-temp anti-seize. I think I'll grind a flat on it before reinstalling, so we can get a wrench on it if this ever recurs.
There's still no real indication of why it abruptly tightened up - everything looks pretty clean, with no sign of heat damage to paint.
Thanks for the suggestions.
View attachment 278197 View attachment 278198
Can an Ashford 30 be run on an 8" flue? My parents are upgrading their 1980's VC Defiant Encore, and are looking at the Ashford. They have somewhere around 27' of straight up, interior 8" class A chimney. They don't want to get into the cost/hassle of replacing a relatively modern, recently inspected chimney. The chimney is newer than the stove, and although the stove was the primary heater in the house, it was used infrequently as a weekend getaway, so it hasn't had many cords run through it. However, my folks are both retired now and are moving up there full time, so a stove upgrade is in order.
They visited a BK dealer who told them that the King would be far too big for their ~1800 square foot, 2 story house in the central Adirondacks, but that they regularly install Ashford 30's or Princesses with 6" stove pipe, a reducer at the support box and 8" chimneys without issue. Is that a kosher install?
I personally think the King would be the way to go, as their only heat source other than the stove is a ductless mini split system.
Perhaps surface area has something to do with it to though.The King turns down almost as low as the Princess.
Thant most definitelycan contribute to the smoke issue....you'll need 2" wide masking tape as well. Wrap it like this...tape will burn off with fire.BKVP- thanks for your input. I have checked the bypass and it seems to seat pretty well. I did discover a problem, but I don't know how much it contributes. The cat has NO gasket, it is just sitting in it's hole. I am going to pick up some gasket material and re-install. This can only help, but not sure if this is the whole problem. at least i'm making an improvement.
![[Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK) [Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/278/278311-6b45b45c3e784166ca00c89080fc3441.jpg?hash=7pvFWRK0hx)
I'd just buy a new cat, try it and keep the old one. You'll know quick enough if the old one was bad when you experience the new one.
Buy some gaskets too while you're at it. Need them every time you take out the cat.
New ceramic cats come prewrapped with a new gasket. I’ve never needed to regasket a ceramic cat either since I don’t have cloggage problems like some folks.
The btu output rating at minimum burn rate considers surface area. It's a system performance specification. Like a 45000 gas furnace, it doesn't matter if that 45k furnace is the size of a refrigerator or a lunchbox.
The thing about cat stoves on low burns is that the heat output comes almost entirely from the catalyst burning the smoke. The size of the fuel tank supplying this smoke is mostly irrelevant to the rate of heat output.
That all said, I do believe it is a good idea to run the stove up above minimum every so often to prevent corrosion. Even at very low burn rates, the catalyst gets really hot and clean but the firebox can be pretty gross.
On my short stack, I actually can't run on minimum for 24 hours in mild weather or the cat drops out. I have to give it some air after 12 hours and then turn it back down again.
I suspect that wouldn't be the case with another 10' of flue, but then my minimum setting would be higher anyway!
100% correct. Every single setup is unique as are the snow flakes. Mine cuts off at 1:30 hrs. It means zero to the next BK owner.Right, if your cat drops out then that setting was below the minimum.
