stove39
Mostly oak and maple.What kind of wood you have and are you going to be burning 24/7?? I started as a weekend burner and quickly went to this as my primary heat...
Did you read the manual.. are there break in fires required prior to burning..Converted my open fireplace to a Montpellier insert last summer. I haven't used it yet but it looks like this weekend will be cold enough.
Do I need some kind of small grate for this thing or just start a fire on its floor?
Your not burning in a fireplace any more.. basically you heve a wood stove in your fireplace.. there is no grate for it but I'd double check your manual.. where you located that your just beginning to burn.. and hows the mc of the wood you have..Yeah, back in July.Probably worth a re-read. I do remember something about not elevating the fire.
Maryland. First daytime highs below 50 this coming weekend. All of my wood for this year is split for at least three years and very dry.
I also burn a VC intrepid 2 on another chimney. Its bottom is a slotted grate over an ash pan. A little different than the solid flat bottom of the insert.
Will do , looking forward to trying it out after staring at it all summer.Farther sputh like Maryland has been warmer.. cool air is on its way.. lots of stoves/inserts have soild bottom mostly due to the lack of ash pan.. let us know how you make out running the new insert..
Have not had time to be on this site in a while , I have a 2009 or 2010 Encore 2 in 1 does anyone know if mine has a place for the cat probe ? If so is there any pictures ? First I have heard of them on Encore. It would be nice not to have to go out side with a flashlight in the winter to see if the cat is lit .
Should get a hole in the heat shield as well. And a small hole for the bracket to hold the probe in place.
With griddle 300 and cat 1050 is this stove throwing any heat at all?Another Intrepid Flexburn update and questions: So with the cat installed now that it's colder, the cat is running about 1050 or so with a griddle temp of around 300. And with the air at around 1/3 or so. With this setting there are some flames. Does this sound like a good crusing temps as for as most VC stoves are concerned? I'm still not sure about the secondary air flap adjustment that's around 1/4"" open when cat is engaged. May play around with that one tick either way to see what difference it makes running the stove. But for right now will leave that alone. Hope to get more information on what the design opening (factory setting) is supposed to be. No, I'm not trusting they have the setting right necessarily. Too many ways during construction they could have got it set wrong maybe one ball (has a ball chain with stop checks) off. If anyone here is running the Intrepid II and knows the factory secondary flap setting please let me know what that is for comparison, thanks.
I would wear shades when looking directly at it, to avoid eye damage.cat around 10000
Totally different stove, but my 2460 has a separate cat air supply..didn't seem to do much any time I messed with it.I believe the secondary flap is adjusted about an 1/8"" too open
Yep, 10000 would be bad. Yea, stove is behaving a little eradicaly. Cat at 730 now but griddle around or a little over 400. There is a OAK on the stove so that may account for some of that being breezy today. The secondary has no thermostat. It has the one air setting for whatever it's been set to. When you switch from damper ope to close you can hear the rush in he flames through the cat for a while till the draft settles down some. Was concerning at first but it's all confined to the cat and never got much above 1300.
