Alpine1
I always load N/S as most here do. Playing Tetris it’s easier that way![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
OK, this must be the 2020 version..I love BKs air wash system. The glass stays so clean even after slow burns.
My observation so farThanks everyone. Taking it forward and placing a dried peice of wood on top did the trick! It's all filled up and burning again! House warming up.
I have to say, I love BKs air wash system. The glass stays so clean even after slow burns.
Is there a preferred way of loading a BK Ashford 30.2? NS or EW? Sorry for my noob questions. Hope this is not another can of worms.
Still have to finish my hardwood floors after taking down that wall. But here it is
Was it OEM BK gasket?Went to replace a leaking door gasket on my Princess with a 7/8ths gasket in which it calls for...the door would not come even close to closing...anyone else experience this? I did not stretch the gasket as I thought you were not supposed to do that? Is that my problem? Thanks
This was addressed couple of years ago. Do not remember the outcome.Went to replace a leaking door gasket on my Princess with a 7/8ths gasket in which it calls for...the door would not come even close to closing...anyone else experience this? I did not stretch the gasket as I thought you were not supposed to do that? Is that my problem? Thanks
Nope....when I called BK today I was told any 7/8 gasket would work...where I bought it they carry BK...if it was a house brand or BK I dont know.Was it OEM BK gasket?
I’m curious who at BK told you this? High density, low density? There’s a lot of people making gasket, some of the “same” size are noticeably different in size.Nope....when I called BK today I was told any 7/8 gasket would work...where I bought it they carry BK...if it was a house brand or BK I dont know.
Who ever the woman was who answered phone told me...I’m curious who at BK told you this? High density, low density? There’s a lot of people making gasket, some of the “same” size are noticeably different in size.
There used to be an amazing woman there that handled warranty calls. Unfortunately she left... raising her family I guess. She knew her stuff!Who ever the woman was who answered phone told me...
OTOH, did you bunch it?I did not stretch the gasket as I thought you were not supposed to do that?
North South...better air flow, much wood can be loaded, less likely to roll into glass door.Thanks everyone. Taking it forward and placing a dried peice of wood on top did the trick! It's all filled up and burning again! House warming up.
I addressed this topic with the office staff. Our gaskets are definitely different than off the shelf materials. Apologies for the confusion.
That is good to know. Our BKs only accepted 7/8 BK gasket. Will not accept any aftermarket 7/8 gaskets. Correct.
Hi Everybody,
just pulled the trigger on a Chinook 30. Looking forward to have it installed.
A quick question: when the thermostat is on "low" and the stove is cold, does that shut off airflow into the stove completely? As you are well aware, a chimney always has a draft, even when cold, and I don't want it to draw air out of the house when it's not in use. Our "Kachelofen-style" stove had a flap in the loading door with which you adjusted airflow into the stove or just shut it off completely by closing that flap.
Thanks!
And you call me the heretic?!?I will go right past prime oak to get to some pine if I don't have my cord laid in for next year yet.
A few more notes, now that you have your coaling situation under control. By far, the preferred way to deal with coals is to just give time to burn down every load sufficiently, before stuffing the next into the stove. I do this by just setting my stove to a burn rate that gets me down to the ideal amount of coals for reload (shown below) in 12 hours, and then load my stove every 12 hours. In milder weather, this may carry the entire heat load of this part of the house. In our coldest weather, this means my oil-fired boiler is kicking in a bit at the end of the burn cycle. But I don’t care, I’m still saving an enormous amount of oil, while keeping the stoves going, and enjoying the whole experience much more than fighting to stay ahead of it. This was my stove at reload time this morning, before work, about 2” deep coals covering the forward 30 - 40% of the floor of the stove, everything behind that is dead ash.Thanks everyone. Taking it forward and placing a dried peice of wood on top did the trick! It's all filled up and burning again! House warming up.
Nah... even my 30.1’s keep the glass pretty clean. This ain’t no Princess. Check out that pattern of clean and dusty spots on the air deflector at the top of my door opening, that’s from the air wash rushing clean air across it, behind the glass.OK, this must be the 2020 version..![]()
Interesting. I believe you, but I’ve never had a reason to try this. I suspect E/W might also give a prettier presentation for ambience burning.My observation so far
For long burns, overnight or really cold days I prefer n/s, otherwise e/w gives me a more complete burn. Nothing left on sides
No modern stove can be closed completely, but cat stoves should typically shut down tighter than a non-cat, due to their ability to maintain re-burn at lower temperatures with longer burn cycles. I suspect that, as Alpine already stated, the heat loss due to conduction might be at least as high as any convective loss with the stove shut down, if you have an exposed metal chimney system. I’ve felt some mighty cold stoves and chimneys, in the houses of folks who don’t keep them running.A quick question: when the thermostat is on "low" and the stove is cold, does that shut off airflow into the stove completely? As you are well aware, a chimney always has a draft, even when cold, and I don't want it to draw air out of the house when it's not in use. Our "Kachelofen-style" stove had a flap in the loading door with which you adjusted airflow into the stove or just shut it off completely by closing that flap.
Jacub said on a "low burn," but we don't know how low that is compared to your burns, how much draft he's got etc. Granted, you must be running the 24-hr stove pretty low..unless you are milking the coal bed a long time and the actual load burn has a decent amount of air being pulled through.Nah... even my 30.1’s keep the glass pretty clean
RDU? Taking a little vacation? I can't imagine many BK owners in NC aside from the Mountains.Great question relating to packaging. Let me deal with this. I'm flying to RDU so it won't be until next week. However, you can always ask to have an order drop shipped to you from our factory.
