Burning conifers will do that to ya..Regency F2400 in house. In winter, couldnt get more than 4-5hrs burn on the Regency without needing a relight with kindling.
[/QUOTE]Burning conifers will do that to ya..Unless you've got Doug Fir which looks to be a little longer-burning than, say, Pine..
I never have, but I see conflicting numbers on the BTU value of it; Some numbers say it's almost as good as Red Oak, around 24 MBTU/cord, other numbers are lower..All I burn is Fir.
The resolution of the stove control could be so much more. This is the EE in me talking.
I've thought about adding a really long lever and dial to the knob so that you could increase the resolution. The stat settings are easy enough to get right enough. A few marks on the dial are a great help for repeatability.
a gear down swooshbox
I'm very surprised that lightweight wood like Aspen would take that long to dry. I assumed it would be even faster than soft Maple, which dries here in less than a year.Aspen takes like 5 years to season. Fir is best.....reburn tube vs Cat stove is the reburn needed to be kept hot with flames, which in turn uses up the wood faster. And when the reburn was in full swing, the firebox is going like mad. Cook us out of the room
Highbeam hasn't responded. He's in his shop drilling a 1/16" hole in his black thermostat knob, sourcing a ultra fine wire to glue into the hole and in line a HF! Wait until tomorrow folks!!
With nights in the low 50s and cloudy days I'm surprised you haven't started already. I turned the heat pump on a couple weeks ago for night and morning warmups. I think you'll be burning very soon. Daytime highs in the 50s and lows in the 40s are predicted to be coming later this week.Nah, it's easy enough to get it close enough to be repeatable with the little dial and some sort of reference marks. Plus I like talking about the BIG O.
Just anxious to start burning this year.
I always mumble it under my breath to the wife. Gotta find the big O.
I’m almost afraid to ask, but how does she respond?
The jury is still out on wood consumption rate in the secondary reburn stove I got for my SIL, to replace her undersized Dutchwest cat stove. Since the new stove will heat her place better, it's going to use some extra amount of wood. Even going to a bigger cat stove for that space, wood use would be more.
The stove is in a large vaulted-ceiling living room, so roast-out is not gonna happen there. The stove is an Alderlea T5, so that was 3K anyway..
okay thanks - even though i recognized what was happening had to do with the wind, it was quite alarming at the time. any suggestions about how to not repeat that in the future, should i have to light a fire again when it's windy? although, it's windy here often, so like you said, it must have been a perfectly-aligned gust. just an issue on the start up do you think begreen, or should i be keeping a closer eye on this load until it's run through the gaseous phase? bypass is closed now,Yes, a strong gust coming from the right direction can temporarily push air back down the chimney, even on a perfect system. That's not a backpuff per se, where unburnt gases suddenly ignite. It's more like a wind puff.
it's 12 degrees C here today, with a strong NW wind gusting 40km/hr.
yes, i figured that one out the first year with my stove. in the shoulder season, the sliding door is always cracked a tad. the first thing i did when it happened was hurl the slider wide open. but thank you for that oneTry cracking a nearby window before lighting the cold stove when its above 50F. It happens on rare occasion here when its that warm and breezy. A possibility to consider.
Quickly cracking open my window always has remedied the situation quickly. Fwiw.
Hey there fellas, can you all tell me if wind gust can be a cause of a backpuff during a cold start? Seems like it would make sense? I just had more first legit backpuff in the 3 years i've had this stove. it only lasted about 2 seconds - came out of the stove collar adapter where the telescopic pipe snugs in, and rolled out the cracked stove door. About 40 seconds into the start of the fire. it's 12 degrees C here today, with a strong NW wind gusting 40km/hr. The fire was starting nicely, and then it looked like someone blew out the birthday candles on my cake, and then the backpuff. caught my attention in an awful hurry that's for sure. any ideas how to prevent this moving forward? like i said, first time happening, but i'd be okay if it was the last time too. preheat the chimney maybe? thoughts? Just a function of the cold stove pipe and the wind?
