Some more general questions : Can you put a pot containing water with a few drops of essential oils with on the top surface of BK insert (Ashford 25) to add humidity to the room?
Would top of the insert get so hot to roast chestnut from the tree across my house
?( I admit that is a bit odd to ask)
Does anyone use heat operated stove top fans on top of an insert when they want a break from the insert’s own fan’s noise?
Speaking of the insert fan, do you run insert fan at max when you run your stove at high and insert fan at low when stove is running low? Or is there any correlation? I assume fan is not thermostatically controlled.
I was at a meeting when I started typing the questions above and now in a subway and keep getting notifications. So excuse me if the conversation diverted into something else.
