That doesn't look very clogged to me, not clogged enough to restrict flow that much. I guess you know when you need to clean it, though..Combustor before vacuuming
You have to understand at 40-60 mph winds the t/stat has to be fully closed on my stove. The wind will lift the t/stat plate (has hole in it) back a forth choo choo effect against the seat. I would think this isn’t good for the life of bimetallic spring. This is why I can’t set it and walk away without checking weather. I live at 6200 ft on top of a hill and most of the time I choose not to burn with high winds.
The Chinook 30 requires 6'' at the back and 9.5'' at the side. The smaller Chinook 20 actually has larger clearance requirements at 6.5'' and 12.75''.Please help me understand clearances.
I am looking at both manuals, Princes and Chinook.
Still deciding which stove would suit my needs better. I want to tuck the stove is a corner as close to unprotected wall as possible. I thought that I could place the Chinook 6" side and back to the wall (which would be great). Now I look at the Princess and I believe it has to be 9.5" and the Chinook manual says 9.5" too. I believe that I read somewhere here that the Chinook needed 6".
what are the requirements for spark protection on the sides with a princess ultra? I believe it is 16 inches on the front.
Touche' on the clogging. Advantage PE, there. Of course, I think my problem is entirely self-inflicted, due to my crazy-stupid-tall chimney. There are thousands of BK users out there, and likely hundreds on this forum alone, and I'm one of the only two or three people reporting this problem. Even at that, it's only one on of my two stoves. The other stove on a 15 foot pipe has no issue.Proportionately we probably have about as much glass area. 2 loads per day is what we average. 3 on extra cold days. 9 yrs now, no clogging.![]()
Hah... you haven't been reading. If you had, you'd know I'm just winging it! No perfection, here... but I'm having a heck of a lot of fun.Im sure you have your setup down to perfection. But if you could do something to better it or to say would you do something different what would you do?
Sorry, maybe I mis-spoke. The prior owner used 2400 - 2700 gallons of oil per year, and we were on track to hit the same numbers our first year here, prior to getting into wood burning. Of course, that was keeping the house cooler all night and while we were away during the day, and still burning that amount of oil.Ashful, I would think what you do would get old real quick. Your feeding 3 stoves and still use 3000 gal of oil? Lotta work and money dude. Any idea how much wood you go through every year. Wouldn't two kings have worked out better than the ashford's?
If this were any other house, I'd put insulation near the top of the list of things I'd do different. However, this is a historic house, and at least eight generations of prior owners have managed to keep it original. I'm not going to be the one to mess with that track record, all repairs are being handled using original materials and methods, and I even chose to forego weatherstripping on my windows, as I've been rebuilding each. My one concession is that I have added storm windows, but they're nice wooden storm windows of your great-grandparents' variety, not those ugly triple-tracks.
Can you stuff chicken feathers in the walls and still call it original?If this were any other house, I'd put insulation near the top of the list of things I'd do
I've spent quite a bit of time learning about this, as I have a lifetime history of living in several different old houses. Like the old rule of putting your insulation vapor barrier toward the warm side of the insulation (barrier in for cold climates, barrier out for hot climates), you really need your outer storm to be more leaky than your inner sash. If not, Jack Frost (and his cousins condensation and mold) will be your new roommates. Folks that want a tighter seal are usually forced toward inner storms, which have other issues.I'm a proponent of modern windows, but an old fashioned wooden window with a tightly fitting wooden storm window outside of it can be pretty good if it's kept in good order.
If I was determined to keep an old fashioned window original, I'd probably look into double-pane storm windows with good weather stripping around the outsides for the winter months... I don't think you'd be able to see the difference, and it could save a lot of heat loss. It's also not actually a modification to the window, as the storm window is a separate piece.
BK Princess Ultra owners....need a favor if you can please...I had a new local dealer order in a convection deck for me. It did not appear to be the correct one from what I have seen so I did not accept it...he had a new display model Princess ultra burning and I attempted a mock up of this deck with it as it did not have one....it covered close to a 1/3 of the top of the cat temp gauge...making the active range unreadable. If my memory serves me correctly from what I have seen here on a few the deck extended beyond the cat temp gauge with a provisional cut out to view the cat temp..no? I measured it at 24in in length by 9 3/4 in width...I think he was sent the wrong one but trying to verify.
Thank you for your sacrifice! Could you show your stove top connection? He may have had the right one.I lost some hairs on my hand measuring.
View attachment 222750 View attachment 222751 View attachment 222752
Wow. What did the front of the cat look like?Follow-up on the clogged cat saga. I received some interam gasket, and was able to shut down and pull the combustor this morning. To my surprise, the combustor was mostly clogged on the back / outlet side. I would love to hear some theories on how this might be happening. Here is a photo of the back side:
This was whitish fluffy stuff, but stuck well enough that it was hard to vacuum clean.
The good news is that, after an hour with a pipe cleaner and vacuuming several times, it’s working like it hasn’t worked for the last year! I’ve been having trouble getting the needle above 9 o’clock, this season, but now...
Thank you sir....that was very helpful...
