To rule out wood- simply go to hardware or grocery and buy a few bundles of the kiln dried stuff and give it a try.
how would changing the type of wood im burning help if we are talking about the bypass potentially not closing fully?
Sure, let me sit around and season new wood for 1-2 years and then try it in my new stove.
My oak is consistently under 15%....is that not dry enough for a BK?
Yup. If the wood was any good the cat wouldn’t fall out of the active zone because the bypass is cracked open. All too often people think their wood couldn’t possibly be the problem because it’s oak or hickory... ignoring the fact it’s full of water.If it is really 15%, that’s plenty dry. But how exactly are you measuring it? It must be near room temperature and tested on a freshly split face to have an anywhere near accurate reading. 25% wood can easily measure below 15% at cold temperatures, or on the outside of an old split face.
But you missed my point. I didn’t suggest you wait 2 years to test it, although you might have to wait that long to really use it as intended, if that’s your situation. Use framing lumber or grocery store kiln-dried packs at $5/ea. to test the stove, and be sure that’s not your issue.
I was keying on your indication that the cat drops out of active and the wood seems to smolder at any dial setting below 3. This will happen with wet wood, bypass fully-sealed or not.
I cant burn below 3. seems to smolder and drop out of active...I mentioned this in another forum, I also notice a smoke smell when I try to burn below 3. My wood is well seasoned oak...I have been hoping it is due to shoulder season temps but we have been in low 40s and now low 30s.
We'll get this sorted out so you're pleased. The cam flip down bypass in frestanding models has some adjustment. Inserts sliding design seems to improve as stove is used. There is some slight vertical adjustment but let's give it week or two. Ill be in my office next week and will look inro this with engineering.I haven’t ruled out my wood yet but my moisture meter crapped out so I have to pick another one up today. Along with some compressed logs from north Idaho or home fire to see if it still does it.
The bypass not sealing well at least on mine is part of the problem I believe but I don’t think it is all of my problems.
Lopi Rockport
Blaze King Ashford 25
The swoosh is here to stay! Not a single complaint since Highbeam started printing decals with numbers. Purchase at:Can't have a part 2 without the t-stat debate!
This insert heated my whole house on medium even the rec room which has been a pain to get warm but the rooms at the end of the house at 68-70 all while not seeming too warm in the fireplace room. So I am happy about that.
(broken link removed)
Oak makes a mighty tough “test wood”, as it is very hard to dry it. I know, as various species of oak make up 90% of what I’ve been burning, the last several years. It takes easily twice as long to dry (think 3+ years) as any other hardwood I burn.
It is my understanding that when the bypass is closed, there is more to burn, creating more heat/energy. So wouldn't wood be less prone to smolder if the bypass is completely closed?
I believe mine is also only around 20%, and it seems to do well enough, to me. Poindexter has also shown that low-teens is no fun, on the other extreme, there's a happy middle ground in that 15% - 20% range.I think the dry wood thing is a bit overblown. My wood isn’t great but it’s not terrible. But, seems to work fine for me. Most of it is around 20% give or take a couple percent, since this is my first year burning and I have no stockpile of dry wood built up. I purchased my wood locally from some farms, apparently it was cut and split last winter.
I just split some oak that is approaching year three in the wood pile ( Top covered and stacked). Some measured 24% on the moisture meter. Pretty disgusting results...
The issue was the discussion of oak smoldering, and subsequent frustration that one should "let it season 1 - 2 years", as if that was a crazy suggestion. We know oak can be way over 20%, even at 3 years split and stacked, it is just about the worst wood for dry time.
Exhibit A:
Please keep in mind that most of us here see new folks come around several times a year that refuse to accept that their wood could possibly be the culprit. Oak is almost always under seasoned, that’s why most people struggle. Nothing against you personally, it’s just a starting point. If you can verify the wood is dry then great!I understand the moisture content / burn efficiency correlation. I measured my wood in September. Freshly split and it was at least 70F outside ( I am annoyed I have to answer this ). According to the blaze king af25 Manuel, wood needs to be 20% or below. Mine is well below that and I am not able to utilize the stoves full efficiency capability - perhaps the most important value, market leading benefit - long, slow burns.
It sounds like there is a potential issue with the closing mechanism of the bypass.
I appreciate the help, it's why I come here. But to be told my (from what I thought) well seasoned wood isn't good enough to get the long burns out of this unit....that is something that should be noted in the Manuel/spec. If even 15% wood doesn't allow for the unit to operate correctly or as designed/marketed under 50% throttle. That's a problem. I'm looking forward to hearing other reviews/ experiences from other AF25 owners. I love the unit, like I said before it's freakin awesome(when ran above 50% throttle). I just want to get the most out of it.
The issue is The possibility of a mechanical problem with the bypass closing fully in the AF25. Everyone is commenting on wood.
