Manufacturers can only sell the combustor for which the unit was tested. This law obviously does not apply to after market resellers.Call and ask, I had no trouble getting a call back from the main guy. Scott or Shaun, I forget. He sent me to the Midwest hearth amazon store since the firecat site sucks at taking orders. The midwest hearth place had the same price.
The M in the part number is for metal. The C in the part number for the ceramic one is for ceramic.
The 30 boxes never shipped with ceramics as far as I know so putting in a ceramic might be illegal? @BKVP
They can sell you anything but like the cat on your car, if the user modifies a federally required emissions device there may be violations.Manufacturers can only sell the combustor for which the unit was tested. This law obviously does not apply to after market resellers.
They can sell it, they just can’t offer it as a replacement for your stove. If you want to use a different substrate, you’d have to do your research in some instances.They can sell you anything but like the cat on your car, if the user modifies a federally required emissions device there may be violations.
The princess shipped with both ceramic and steel so they’re interchangeable imo. The 30 box never shipped with ceramic so is putting a ceramic cat in a 30 box a violation of federal law?
After some research. The firecat and Midwest show pictures of the cat but the don't have the small tabs on the front of the cat. I found on Amazon condar sells a steel cat that the picture does have the taps but it's 16 dollars more and $15 shipping. So my questions is how important are those tabs. Thanks.
I’ve ran into a few diesel foil cats in vc’s, total prices of crap!I’ve never bought a cat for the Ashford from Condar, but I did buy several SteelCats from Condar for my small army of Jotul Firelight 12’s, and they were all cheap diesel foil garbage that self-destructed after just a few uses. BKVP has alluded to this, stating that only Durafoil SteelCats are to be used in BK’s, although he has avoided favoring one cat brand over another, by calling out who uses which.
If shopping Condar, you would want some way to verify they’re using Durafoil. It’s easy to tell from a photo of the cell structure, as Diesel foil looks like a rolled up sheet of corrugated cardboard, and Durafoil has consistently even rows of formed cells.
That gives me an idea!I wonder if the 30 box would test differently with ceramic. Emissions, efficiency, output. Or how the ceramic might effect the smoke smell issue.
Might be the next hot upgrade!
For sure this question will come up in the future since the ceramic cat costs almost half as much as the steel cat that was oem.
Even if performance is unchanged, most folks will choose to save the money.
Have a quick question about the BK warranty, Mi King was installed 7/15. My air control spins around and around, is it still under warranty?
If anyone has had this problem and wants to give some input it would be appreciated. Thanks!
More than likely it is the set screw. Turn rod clockwise with pliers until it stops. Align white line on knob pointing straight down, secure set screw...Have a quick question about the BK warranty, Mi King was installed 7/15. My air control spins around and around, is it still under warranty?
possibly if is new still curing. give a little more time. I have the princess also i don't smell nothing after the curing process.
The rtv bed under that gasket should be deep and continuous. The gasket channel also contains the glass retainer nuts and studs so you need lots of rtv. The fact that you were able to adjust the gasket tells me it’s not installed right.Anyone have the fix for the light smoke smell between the two door hinges (Left side) on the princess? I'm having that issue with lower air settings when the cat's engaged, pretty much from engagement point on. Had this stove for about a week now. Not a complaint, just trying to get it dialed in.
I adjusted the door gasket and checked the gasket position in the door frame.
Is that gasket supposed to have an RTV silicone bead just on the outside edge or is it supposed to be completely bedded in silicone? Mine seems to be just on the outside edge of the 7/8" gasket.
Doesn't seem to be an outside temp issue, or draft issue on my stack. I consistently pull at least .10" of water on my chimney.
I'm currently using my single wall connector 3 feet going into a 90 bend. Contemplating going to double wall and 2 45's as the manual recommends, but have not had issue with my setup on cat and other stoves on this setup before.?
Help would be appreciated. I did do a bunch of back reading on older threads but it seemed more related to the ashfords.
Hi BKers,
I am planning out my house:
If I was to go with Ashford 30.1 what would be the ideal total pipe length (double wall inside and excel outside. Two 45* inside...to avoid any issues with smoke smell....
Cheers
