Woody harrelson
I have to look through the glass with a flashlight to see what the hell is going on. hahaha that's a low and slow fire
I never shut mine down either.
yeah but we got lucky with how the hurricane went thank god!Lol doubt it really matters much. It's so crappy out here.
At 12' mine doesn't like to be run much under 1.5.... I would imagine there are slight differences from stat to stat and wood is also a factor.from what I have read a better draft will allow you to run a lower thermostat setting, but like I said, it's only what I have read
I'm curious what everyone's stove top temps are when they have the stove setup for a 24hr burn. Are you able to keep a 500 stove top temp and still get a 24hr burn. Are you higher or lower then 500? Thanks
Measuring stove top temp on a bk cat stove is a almost a waste of time. The cat is the heat source during most burn rates but on high rates the web firebox makes heat. Since that hot cat, think 1000+, is right under the stove top measuring stt will just be an indirect measure of cat temp. So that hot spot on top will always be 500-700 but what's important is how much of the rest of the stove is 500-700. Was it this thread that showed the pic of a new stove top with flat paint just in a circle above the cat?
Thank you. It's just been cruising at 500 stove top temp all morning and putting out a lot of heat. Have fan on medium and ceiling fans in the room (big room) and it's starting to disperse the heat nicely throughout the house. In the 40s here in mass and rainy/windy.
Chimney has some smoke coming out of it but not too bad, kinda wispy smoke. I would imagine i would see more smoke given the weather?
I did the first break in and cooled it down but just kept running the stove in the morning, bringing it back to temp. Didn't really feel I have to shut the stove down.
When the cat stalls that means your fire isn't making enough heat and smoke for it to stay active. Usually it's because you turned it down too low. The next issue is your wood quality. Wet or green wood requires more air. Finally draft. This time of year draft is weak due to warm outside temps so a higher setting is needed. If the cat temp is active and the stove cruising along then there should be no smoke. Steam from wet wood is white, smoke is usually blue.
The tstat will prevent the stove from over firing once the bypass is closed.
Whaaat? So I can just crank it up all the way with a full load of wood and not have to worry about it? Are you saying that it's essentially "over-fire proof" by design?
Not that it won't operate on 1. it will just stall eventually.
I ran 13'6" of pipe all year last year. It was enough in cold weather, but the stove was really tempermental at low tstat settings, I seem to recall it settled down below freezing and ran great below 0dF, when I wasn't really using low settings anyway.
I added two feet of pipe over the summer, A30 manual calls for 15' minimum, I got to 15'6". Stove runs like a dream on low settings with the outdoor ambients in the +40s dF and the Tstat at 1 oclock.
Same here, ran great below 40F. It's running today on 1.5 @ 50F outside. Can't complain,with only 12'
I probally should get it to 15' before winter.
Straight shot up, or do you have any elbows?
Same question for you, Poindexter...
Just had an Ashford installed here, height is right about 16' with 2 30 deg elbows in the attic space.
Yup. I ran mine at wide open throttle from mid December in to early February last winter. Most of the time I was loading every 12 hours, when it was really really cold out with the fan kit on high and the house fan on high to get warm air back to the bedrooms I was filling the box with birch at 0530 and 1900ish, and filling the box with spruce at 0200 and 1600ish.
Didn't even discolor the enamel.
