- Oct 25, 2006
- 391
Marty said:That is a real nice setup Andre. Are you tied into the grid? I'd be interested in hearing all about your whole system. Is there a thread where you lay it out?
Grid is about 1000' (thru the woods) and much $$$ from the house and shall remain that way , I would not cut down trees so it would have to be underground up the driveway. And that driveway went thru some mud holes that now have some very large rocks in them.
Not a very "showy" system. Started with two Aladdin oil lamps, a worn out Briggs driving a car alternator.
As I got more free money.
Added some batteries, and 12volt lights.
Got some used PV panels.
Added a small inverter.
Generac 3500 watt generator, one of there first using the overhead valve engine (that looks a lot like a Honda), during the short time they were selling them under the continuous rating, same gen today is sold as 4500 watts.
More batteries, yea not suppose to mix old and new, but if you watch them close you can get away with it.
Put up 1000 watt wind generator.
Got larger inverter, Trace 2512SB.
More PV panels.
Currently working on the diesel generator and the battery pack is in real bad shape and needs to be replaced. Thinking about jumping to 48 volts, which would mean a new inverter at the same time and rewiring the PV and wind gen. Also the higher pack voltage is subject to more electrical codes then 12 volts.
Everything is almost always in some state of being modified.
