Hi folks, long time lurker, first time poster.
Almost a month ago I purchased a '96 fireview 201. I used this site to help determine that it is a well -regarded stove and company. The previous owner had just replaced the baffle and touched up the paint.
After some minor fixes (replacing gaskets and installing a combuster) the stove is a reliable heat giver and I'm impressed with how little wood it goes through and how it holds onto substantial coals overnight. However... previous posts about similar stoves tell of stove top temps reaching 600-700F and 500's being the norm. The highest I've seen on mine is 450 and that is with the wind howling and outside temps in the 20's. I've read the posts describing the best use practices, and I've peaked at the combuster glowing red so I know it's working. The space I'm heating is well within reason (under 1000 Sq ft) but it's not well insulated and I am hoping to squeeze out more heat from the unit.
Full disclosure, I'm burning ash at various stages of curing. Absolutely nothing green, but the majority has spent 2.5 years in long log form and for health reasons I've only recently been able to start sawing and splitting. Not ideal, but it is my current situation.
So here's the question: do the grizzled veterans of fireview operations think the wood is the reason why I'm not reaching reported performance for this stove? I should add that I've burned wood for decades using the same chimney rig hooked up to a VC encore non catalytic. Flexible SS liner in a masonry chimney. I just removed the old stove and replaced it with the Woodstock, plug and play.
Thanks for your expertise!
