recently got a 1979 hs tarm mb 55. i was hoping to use it on a chimney with a 8" round flue but after reading specs discovered they recommend a 8 x 12. i have used the chimney and it had good draft . my biggest concern is that they recommend having only one 90 elbow or two 45's. in the pipe. ???? ii need to use 2 45's. i do realize the importance of seasoned wood. been using wood for heat for at least 30 + years, but never had a wood boiler. any feed back would be appreciated. thank you.
