Sweet setup!At the Biltmore mansion in Asheville, NC, the banquet hall fireplace:
What size chimney brush do you reckon they used?
Also home to the 5 course meal at $98 per plate
![Eek! :eek: :eek:](/talk/styles/default/xenforo/smileys/bigsurprise.gif)
It's going to take a lot of work, and it won't be cheap, but with good sealing, tight windows and good insulation the house will be much more comfortable and a lot easier to heat. I would still advocate for restoration of at least the main floor hot water system. It's good to have a primary heat system for fall back and supplemental heat. Insurance companies like this and you never know when you are going to get sick, called away or just want to take a vacation in the future.Heat for this? All depends on how much you want to spend on insulation, windows siding etc.
Which software are you using. A 3d reperesentation is such a useful tool.
Get a wood cook stove for the kitchen and you can have free domestic hot water in the winter. @coaly uses his Kitchen Queen all year in an old house. An additional medium size heat stove in the living area would keep the house very warm if you modernize it.
A fantastic way to visualize both for yourself and others. I have a question. What is the area to the left and back of the kitchen. Porch area? We've found with a semi open floor plan that we can heat up to about 30ft away to a comfortable temp, but beyond in extended rooms and upstairs the temps remain about 7-10deg cooler. Heat close to where you want to spend time. Take the radiant heat from the stove into account. Warm air will travel beyond that but will take a temperature differential to do so. Bedrooms a lot of times can be lower and not be uncomfortable. Moving wood in - we have a small cart and hardwood floors, so we're able to bring wood in with little upset and effort. Just saying, because now you have the opportunity to choose. We camp near cassville in the summer, not far from you, beautiful area.Home design, an app available through the App Store.
Electric baseboard heaters are expensive. Have you considered ductless mini heat pumps? They cost almost nothing to run.
Look more into trying to push any warm air to lower levels. Some are successful, most are not. Convection up is a lot of times very easy, and could take place all on it's own. It looks like the stairs leading up would be very near the stove in the living room, leading to a direct path for warm air to go up, and for cold air pooling on the upstairs floors to travel down and directly to the stove. It also means that the chair closest to the stairs would be cooler. I get comments from visitors sometimes stating that the place isn't warming up very much - but switch chairs and the difference is clear. Just the opposite if it's getting too warm.Ok, so the area to the left and back of the kitchen is a covered interior wraparound storage area that has plagued wood ceilings supporting the upstairs rooms and cinder block walls. I estimate this was put up between 1920 and 1940-ish? There is a door that leads out to the front yard of this area but the rest of it is like a prepper bunkers dream. I’m on able to open that up because windows would just go to earth. I agree about bedrooms not needing as much heat as the living spaces, I’m happiest when it’s about 60° and I have plenty of blankets around me. One of the people on this thread suggested I consider a wood cookstove, a kitchen queen for example, and I have been burning my Wi-Fi looking into that. Using fans to push warm air down and up. Cassville is beautiful!
Looks a bit like what a previous owner started with our house, and we're continuing now! The original portion of our home is circa 1840 as well. We have a whole-house forced-air system on a thermostat set to 58, but prefer to primarily heat with wood. We have two woodstoves - one in the central living room, one in the annex (a converted attached garage). Ignoring the annex, our home would only be about 1400sq ft, mostly 1 floor, with one 400sq ft room upstairs.
We light the main woodstove every morning when we wake, tend to it all day (we work from home) until we go to bed around 10. Keeping bedroom doors open, this keeps every room at least 65 throughout the day, with the central living room even warmer. In the winter (upstate New York, 20 degree days for a few months) our furnace consistently kicks on around 1 or 2am. We keep a few bedroom doors closed at night (teen kiddo wants his door closed, as do we, so he doesn't wake us or baby in our room up) and if we didn't have the furnace going those rooms would be in the low 50's in the morning. Our attic was recently re-insulated, and we know we have a bit more work to do on insulating crawlspaces under the various additions that were made throughout the years, but we are SUPER grateful we have the forced air system.
My house was built in the 1860's(ish), and then added onto every decade after that. When we bought it, we gutted parts of it, but kept some of the ceilings and lower level drywall. I regret that decision every time I have to get in there and fix something, and have to move what seems like every piece of furniture. 4 Years later, I am still crawling in tight spaces so I can repair the issues I found
I love seeing the progress by the way!
Good to know. My primary concern with the heat is that there is no ductwork - and the one stairway is on the far side of the rather long rectangular houseprint, the furthest point away from the kitchen, where I am now thinking the Kitchen Queen will be located. I work from home some of the time, and try to travel NEVER, but the upstairs electric baseboard heat can be used to supplement heat (occasionally). Haven't even seen the attic yet, not sure what's up there...I am anticipating the caulking gun will be actively used once I get in there!
