trehugr said:Heaterman, with there being so many kinds of PEX, what specific brand would you use for the system your using ?
trailhound68 said:I have 1" pex about 75' underground each way. The tube is in insulation, that is in 4" electrical conduit, glue joint.
Most of my tubing is 24" plus below grade with no water issues.
2.beans said:heaterman when you spray foam the ditch is the pex in pipe or do spray a layer down lay the pipe then spray over it? on the insulseal how rugged is the outside insulation? thanks
heaterman said:2.beans said:Going to 1 1/4" vs 1" tube greatly reduces the flow resistance (head) on any run over 75 or so feet or that requires more than 6-8 gallons per minute. It makes the difference between having to run an 0011 vs a 007 Taco for example. Substantial savings in long term electrical costs between those two circs.
Heaterman, Where do you get your fittings for the 1-1/4" pex? I have 1-1/4" Rehau's Paupex and having a difficult time finding fitting that will adapt to NPT. I can't afford the tools for Rehau's Everlock fittings. Are there any compression fittings available that will work with this pipe?
Don
Don L said:heaterman said:2.beans said:Going to 1 1/4" vs 1" tube greatly reduces the flow resistance (head) on any run over 75 or so feet or that requires more than 6-8 gallons per minute. It makes the difference between having to run an 0011 vs a 007 Taco for example. Substantial savings in long term electrical costs between those two circs.
Don
Don, Both of the tubing brands I use have their own fittings for large bore tube as you already know. Viega uses a pretty much standard type fitting which is interchangeable with anyone else's but the connection is made using a pressed on stainless steel sleeve not a ring. There are hand operated press tools for 1" and down but you have to use an electric tool similar to The Ridgid ProPress system for 1 1/4" and up. They are not cheap, about $2K for the tool and the jaws for different sizes.
The Rehau you obviously know about and have already checked the price of their hydraulic press tool. OUCHYour local distributor should have access to a set of tools you can rent at the very least. I have to say that Everloc is the appropriate name for their system. We were pulling a pair of 1 1/4" lines in a 220' length of InsulSeal that a customer had installed himself a couple years ago. We got about 150' pulled in and the pair of tubes locked in place probably on a joint that wasn't fully inserted. Working with three guys pulling and two pushing, we couldn't get the tube to budge either in or out. I decided to go for broke, as we were screwed either way and tied the 1/2" nylon rope to the tow hook my Sprinter van. The rope stretched what seemed like 4 feet and the van was actually spinning its wheels when the tube finally came lose. The Everloc couplings held under all that strain. We pulled the tube all the way back out to check and everything A OK. Amazing
Tools like that are just something a pro has to add into the cost of doing business.
I don't know of any manufacturer that makes larger bore fittings that use a basic clamp type attachment method. You just need a little more oomph when your fooling around with that size pex. It gets pretty nasty to handle........My boys call it "wrestling the anaconda". Glad they are both the strapping young lads that they are when it comes to the 2" jobs.
Seton stove said:I'm having problems getting a large slab to heat up using a Seton 300...his biggest I believe?
Running 3/4" line Pex 150' in a 4" flex line that's uninsulated except for 2-4" of rigid over the top...all above groundwater.
At the manifold in the warehouse (uninsulated), I'm tapping into 7/500' 1/2" lines and seem to only be getting 2 to 2-1/2 gallons of flow total.
Temp is around 170 degrees leaving the heat exchanger near the stove and 130 at the end of the 150' run...the return is down around 100 degrees.
2 questions on the 3/4" supply/return lines...
Should I upsize to 1" or 1-1/4"?
Should I use insulated PEX (if I upsize), or spray foam (If I retrench)...(has anyone tried those small cans or containers of spray foam?...Is there a special density or ? when purchasing it?
Fred Seton has suggested I install a mixing valve between the heat exchanger and the pump going to the warehouse to keep the return temp up. Does this sound correct?
Regards, Scotty
PS...I'll be posting about my "MAJOR" creosote problems along with some pics that will have you smiling.
