Take a look at the Vermont Castings Aspen C3. It is right-sized and qualifies for the 26% tax credit (which applies to the entire installation cost). There is a VC dealer in Manhattan, KS if that helps.
I want to like it…… would like to hear a few more reports as I was considering the Aspen for a bit. Decided to go bigger.I'm not sure how excited I am about the automatic air control
My air setting stays in the same place after the fire is lit 90% of the time.At first the auto air sounded like a bad idea to me, but my only experience with thermostatic control is with a broken VC Defiant I. Seems that most people like the thermostatic control on the BK stoves, which is the same principle. The main difference being the thermostat is adjustable and there is a bypass. Could be nice to just light a stove and walk away.
FWIW, we bought our VC Resolute new and the thermostat worked great. VC continues to use this solution, including in the Aspen C3. I mention this stove because it is right-sized, qualifies for the tax credit, and is not a budget breaker. The guys at MF Fire are young and smart engineers. I'd love to try a Nova2 for a year to learn how it burns under varying conditions.At first the auto air sounded like a bad idea to me, but my only experience with thermostatic control is with a broken VC Defiant I. Seems that most people like the thermostatic control on the BK stoves, which is the same principle. The main difference being the thermostat is adjustable and there is a bypass. Could be nice to just light a stove and walk away.
I do the same, but I have to be around for the first 30-60 minutes after lighting to slowly close the intake. The Aspen C3 is light it and forget it. Definitely a stove I would recommend for someone new to woodstoves.My air setting stays in the same place after the fire is lit 90% of the time.
As a second stove (for a busy person) that was/is still appealing.The Aspen C3 is light it and forget it.
Sorry, I thought the Aspen C3 was retailing for about $1200. Are you saying the dealer wanted $1600? Or is $1600 for the entire installation after the tax credit?$1600 cost of the VC Aspen C3 and flue (after factoring in the 26% credit for the Aspen C3).
I would not buy a stove with the intent to modify it. If the stove is intended to last decades, then it would be good to save up for one built to last for that time with minimal costs over the lifetime of the stove. Let's say it costs $1000 more. Over a decade of service that is only around $8 a month more, which at least to me is better than having to buy 2 cheap stoves during that same time period.
If you just want to buy one stove and have it last, don't get the Vogelzang. Honestly I would only ever buy a Vogelzang stove if it were the last option.
It always does. I’m a fan spending the extra money up front and doing right the first time. Don’t rush tax credit is still available in 2022. I’ve looked at the parts diagram for the c3. It looks simple enough. Bi metallic spring up high with a chain running down the back the the air control flap. Yes there are more moving parts, but it hit the efficiency numbers and most stoves are using catalytic converters to hit those numbers. Spring failure, corrosion or it getting packed with ash ( not sure how) or the chain coming unhooked somehow seem to be the most likely failure modes that could see for the c3 system.This is adding up quickly though.
it has a bigger firebox correct? No automatic air control. I run my stove on low 90% of the time so if that’s how you run the Vogelzang seems like the would have similar heating abilities on the low end. High end is where the difference would be. I don’t trust the epa numbers to reflect how it works in my house. Well accept for the C3. It’s automatic air control gives me more confidence in its number.really get almost double the heat output from the Vogelzang
That's no problem. It just needs a 4"x3" transition adapter.Another minor thing on the Aspen - it has a 3" OAK inlet and I currently have a 4" duct. I figure I can find something to adapt down from 4" to 3".
Thanks! I hadn't even had time to start looking. It's good to know these things exist.That's no problem. It just needs a 4"x3" transition adapter.
You have experience that says the Aspen is sized correctly. That takes so much guess work out. Nice work on sealing and insulating I’d say.That's probably the best testament to the condition of the house now after I remodeled. If we put stock in the EPA numbers on the Aspen,
Probably. Springs in this application probably outlast any/most other components in the stove.Maybe I'm getting into the weeds here
You have the right idea. I think a clean efficient burn is more important to me than a long one to me. I let my heatpump kick in instead of getting up to reload. On a average cold night that probably keeps the house 2-3 degrees warmer. In three years I have had one load that overfired and I wished I had an air control on the OAK. stove is fine. I would hope that the C3 would have been able to shut down the air to prevent that over fire. (I think I read a post on here maybe by someone who was with VC. Found it.) gave some confidence in the design and testingOAK side - maybe that wouldn't be a bad idea for safety, if nothing else, and leave it fully open otherwise. I wonder what would happen if I dialed that down slightly for an overnight burn... I'm sure that's not sanctioned by the manufacturer, however.
www.hearth.com
Yes, they typically stand up for a long time. Also, this is user-replaceable if there was a failure. You can still get replacement bi-metallic springs (and the rest of the thermostat assembly if need be) for a 40+ yr old VC Vigilant.Do the bimetallic springs generally hold up in stoves fairly well (the ones that have them
![[Hearth.com] ~1200 Sq. Ft. Stove Recommendations [Hearth.com] ~1200 Sq. Ft. Stove Recommendations](https://www.hearth.com/talk/data/attachments/280/280942-6a5f29bfd9a800123927df480726d9b3.jpg?hash=34H1J939PR)
