Just started burning it, seems to burn slower and less intense than other wood but seems OK. I've never burned Black Walnut "Opinions"?
ddown said:Just started burning it, seems to burn slower and less intense than other wood but seems OK. I've never burned Black Walnut "Opinions"?
been cut and stacked 4 years.
Jack Straw said:In the 1980's I worked in a sawmill and when we cut B.W. the owner of the mill would come and oversee the cutting of the wood. I can't remember what it sold for, but it was a big deal whenever we did anything with it. I even had to coat the ends to prevent checking. I cut a big Hickory tree down today and I measured each piece to length. I didn't want to waste any of that either.
JerseyWreckDiver said:Jack Straw said:In the 1980's I worked in a sawmill and when we cut B.W. the owner of the mill would come and oversee the cutting of the wood. I can't remember what it sold for, but it was a big deal whenever we did anything with it. I even had to coat the ends to prevent checking. I cut a big Hickory tree down today and I measured each piece to length. I didn't want to waste any of that either.
I spent the better part of my life as a professional woodworker. Walnut is pretty much the most expensive domestic hardwood we have. A pleasure to work with too, if you can get somebody to pay you to work with it. Mostly cheap asses with no taste whatsoever, "Make it outa pine or oak, then stain it dark like walnut"... Last several years of my career I started refusing to stain wood ever again. Told people, if you want it the color of Walnut, your going to have to buy Walnut. Stain is an abomination in my world. Take a piece of Walnut and sand/plane it good and smooth then put some thinned out Linseed oil on it and let it soak in a bit, couple more coats full strength, beautiful depth & color... Interestingly enough you can make a good dark stain from the ripe walnut hulls & a really good anti-parasitic medicine from the unripe hulls.
