10 feet from ridge or 10 feet from a structure?
Bella77
16
lost in the woods
I'm confused is the 10 feet in the 10 ,2 ,3 rule way from the nearest object within the 10 feet after 3 feet from the roof. Or is it 10 feet away from the ridge.
To the nearest roofline or structure.
[Hearth.com] 10 feet from ridge or 10 feet from a structure?
So from that if I have a 12/12 pitch I would have to have a chimney height of 12 feet in order to get proper clearance from the nearest structure. I'm 10 away from the ridge as it stands but I have 12/12 pitch so in order to be 10 feet away and the an additional two above that I would have to come through the roof at 12 feet correct?
Here is the actual verbage:
"Chimneys shall extend at least three feet above the highest point where it passes through the roof of a building, and at least two feet higher than any portion of a building within ten feet.”
Your calculation sounds correct. From the description it sounds like you have a steep roof and are penetrating it at a low point. If so, yes this is going to be a tall pipe. Is there any possibility of moving the stove further into the room for less projecting through the roof? If not, this 12' chimney will require 2 roof braces one at 5ft and one at 10ft above the roof penetration.
