Sure it's been asked before, but can you use gas with 10% ethanol added in a modern 2-stroke engine? They didn't even have the stuff last time I used a chainsaw. Also, what octane should I get?
EatenByLimestone said:Gendrons in Troy is right off theNorthway. The Ballston Spa guy is pretty far off the road. I don't think he would be closer for you.
Matt
EatenByLimestone said:I use the Western Ave (Rhodes I beleive is the name) station. Coming from the Northway it should be just before the 155 intersection. Across from the Hewitts garden center and bowling alley. They also sell Amsoil there if you are looking for it.
oldspark said:I wonder why any one what mess with it in a 2 stroke, is it the only gas you can get?
That sucks, I was told that about Maine but found regular gas there when I was there for my job. Is it a state law or something in Ohio?HittinSteel said:oldspark said:I wonder why any one what mess with it in a 2 stroke, is it the only gas you can get?
Bingo.... all gas in my area has ethanol.
firefighterjake said:Geez . . . guess I'm doing everything wrong then . . . been running the ethanol-gas in my saw for the past year or two now . . . maybe I should let my saw know that it's no good and will surely be damaged.
Honestly, I did a whole bunch of research on this issue when ethanol hit Maine and there was a real concern by us snowmobilers using two-strokes since the manufacturers today have really dialed these machines in to be as efficient as possible and no offense to anyone but I was a lot more worried about damaging a $8,000-$10,000 machine vs. a $300-$500 machine (not that I have money to spare).
In the end based on what I researched . . . and based on the experiences of folks using ethanol a year or so before us out west . . .
a) ethanol/gasoline is probably OK for most newer machines . . . but for older machines the gaskets/hoselines/other rubber-type parts may not hold up
b) ethanol/gasoline is OK if you use it short-term, but if you're looking to store it in a tank for several months it is best to add a gas preservative . . . preferably one that does not have alcohol in it (i.e. go with the Marine Stabil vs. the regular stuff was one bit of advice I had . . . I think I went with T-1000 or some product like that . . . can't remember the exact name.
As I mentioned . . . I went all winter with zero fuel issues in the sled . . . and zero issues with the chainsaw . . . for that matter also no issues in my lawn mowers, ATV, SUV or two cars which are admittedly four-strokes.
Now as for the octane levels . . . I used to subscribe to the "more expensive stuff is best", but in the past few months I've been running the cheap stuff with no issues . . . I think it is more important to use the higher octane if your manual calls for the higher stuff . . . and what is even more important is to make sure your gasoline source is good and reliable . . . in other words, no issues with water or other contaminants.
Does this mean it's not a good idea to use mixed gas over a month or so old?HittinSteel said:I use 93 octane (with 10% ethanol) and mix it with the best possible oil available, in my opinion Stihl Ultra. When a month is up I won't run it in my saws anymore, but it is fine for my junk trimmmer, blower and lawnmower. If they blow up, I can replace them with something nice!
