I was holding back on any modifications until I could determine how necessary the pump was. Now I'm torn on whether to keep the stove and see what the best way to reduce the noise and vibration is or trade it back for something else without the pump. I don't need multi fuel. It was more of a backup plan if wood pellets were tough to get or expensive.
I did jam a rubber dog Kong under the bracket between the floor base of the stove and its less rattley. I think the rear service panel could greatly benefit from some sort of foam tape (if safe) or high temp insulation where it sits against the rear. Heck, even cramming an insulating material in the area of the air pump may work too. I just don't have the materials on hand to test. What's interesting is if I hold the pump still it's less noticeable, yet it's mount on rubber pedestals that allow it to jolt pretty harsh. I'm sure the thump is transfer through my body though.
What kind of ideas have you guys thought of with this stove?
Is it ok to post links? If so here is a good picture I found online. (broken link removed to http://www.heatredefined.com/assets/images/products/2903/bottom-auger__product.jpg)I"ve never looked back there, I didn't realize the pump was already mounted in rubber. My stove is minimum distance from back wall, so it's not easy for me to just look in there yet. So, I'm learning from your posts![]()
I've tried a ton of different things with my pump. None of them ever solve the problem permanently. Some days it's really loud and others I can't even hear it pumping.
Question though...
They claim if we don't run the pump it could cause the igniter tube to collapse. Can this really be possible? Is one tiny pump of room temp air every 5 seconds really enough to keep a pipe like that cooled after hours and hours of firing?
I never considered disconnecting it completely but after reading up to this point I feel that's definitely a possibility now. I'll just manually fire the stove every time after cleaning.
The burn pot is getting most of its air from the OAK anyway so the pump should really have nothing to do with keeping the fire going anyway.
I'm with you. I got the multi fuel for the flexibility in case corn or cherry pits get really cheap. I've burned nothing but pellets so far and don't plan on changing that anytime soon either.
In theory we could just disconnect the pump for pellet use then reconnect it if and when we need to switch to multi. Just be sure to clean out the igniter tube also.
Anyone out there running it like this? Or tried it and maybe burned your house down and can tell us to beware?!
We bought ours online. It would probably be a major hassle to return it. Not to mention I've already had it now for 4 months. I doubt they would even take it back.
Also, I'm stubborn as hell. I won't let this thing beat me. I'll figure it all out or I'll go insane trying and take a sledge hammer to it. Then I'll buy another!
I'll let you know. I don't think i would necessarily be doing any kind of modification, just unplugging the pump. I would keep the igniter in place and just clean out the tube from time to time. And have a fire extinguisher nearby just in case!
Can't imagine why other stove manufactures can shut the igniter and pump down after startup and not Englander? I have three stoves that use a pump to light corn. The Bixby is an extreme ignition cycle when switched to corn mode using two 500 watt igniters with the air pump going. I've had not had any starting issues in the five seasons I have had it.
Read today that the Harman multi-fuel has an air-pump, so it's not just an Englander thing.
I reached back there today while stove was cool for weekly cleaning. Yep, nice soft rubber mounts pump to bracket. The problem is the bracket is mounted to a piece of sheet metal that is essentially a drum. I banged it a couple of times and sure enough, it rings like a woofer. Options are to 1) stiffen the sheet metal that it mounts to so it doesn't resonate like a drum 2) isolate the pump bracket from the stove bottom with rubber mounts 3) relocate the pump bracket to a stiffer part of the stove. The way it's mounted now may not be ideal
I could and probably will. I just left it on for our County permit inspection and haven't had time to loosen the exchaust and OAK connections to pop it up. Unfortunately, mine has 2 holes that need to be slid over the exhaust vent and OAK first before securing to the stove. What's ironic is that there is a plate for each "port" that attaches to the rear panel. If I remove the plates from the panel it allows me to slide the large service panel up and over off the stove through 2 notches cut straight through the bottom. The 2 plates are let behind unless I disconnect the vents....Maybe you've already done this, but it never hurts to ask...what about pulling the back cover off the stove? I can hear my pump run every few seconds, but it's not annoying. Now...the back cover on the other hand...rattle city.
