Fisher Stoves
Bob Fisher is credited for conceiving and producing some of the first "airtight" welded steel plate stoves. He was raised in Oregon where he tried his hand at many jobs, including logging, farming and welding. It was his welding skills that finally set the stage for his invention.
After buying an A-Frame in the mountains, Bob discovered that heating with wood in the existing fireplace was extremely wasteful. So he came up with some ideas, and in Bob's own words:
"I just drew it up and built it - I knew in my mind exactly how it would work, and sure enough, when I got through welding those pieces of iron together, it did work!
"We sealed up the old fireplace except for a 6 inch opening in the chimney for a flue-then I put that first stove in place. It heated the entire A-frame, and we had 100%, flame control. The stove was just a little slower to react than a gas or oil furnace, but we could turn the wood flame up or down anytime we wanted . . . and we could cook right on top of it! "
Soon all his friends and neighbors were demanding Fisher Stoves. Bob turned to subcontracting in order to meet demand and then to franchises, which helped create over 1/2 million of the original stove models.
The stoves were built from heavy 1/4" steel plate and 5/16" thick steel plate top. They used doors made of cast iron. The "Bear Series" single door stoves have a 6 inch flue and were named "Papa Bear", having two air intakes, logs to 30". "Mama Bear", having two air intakes, logs to 24" and "Baby Bear", having one air intake, logs to 18".
The "Fireplace Series" double door stoves have a 8 inch flue and were named "Grandpa bear", which measures 29 1/2 " across the top plate. And the "Grandma Bear", is 25 1/2" across the top plate.
All stoves made to go into a hearth or fireplace were called "Inserts". They were later available with glass doors.
Freestanding Pedestal type stoves were the "Honey Bear", and the Mobile Home approved "Goldilocks".
The "Coal Bear" was the coal burning stove that featured reversible grates.
The largest model "XL" had two doors and a 10 inch flue capable of heating up to 3000 square feet.
As stove technology improved, the Fisher stoves fell out of favor and the company greatly slowed production by the mid-80's. A few isolated franchises remained, but no designs were ever produced which met the EPA standards in the US.
As of this writing, Fisher stoves are still available in New Zealand. The newer stoves look relatively similar to the original models except for the addition of a glass door and brass trim.
We have more info on Fisher Stoves at various places on this site:
Link to all things Fisher Forum : http://www.hearth.com/talk/forums/fisher-stove-information-parts-history-and-more.28/
Typical Fisher Stove
Here is the owners manual for the Fisher Fireplace Series Models made after 1980: http://hearth.com/images/uploads/fischermanual.pdf
Here is an OLD manual for Fishers made before 1980 - http://hearth.com/images/uploads/Fisher_Manual.pdf
Manual for older Fisher Inserts: http://hearth.com/images/uploads/fishinsertmanual.pdf
Another manual for Fisher Stoves - one of the earliest UL manuals, baby, Mama, Papa
http://hearth.com/images/uploads/Bear_VI_Series_Early_Manual.pdf
Two more manuals! Honey Bear and Goldilocks - Thanks to member @coaly
http://hearth.com/images/uploads/Honey_Bear_Convertible_Manual.pdf
http://hearth.com/images/uploads/Goldilocks_Manual.pdf
Original sales brochure for Fisher Stoves -(front of ad)
http://hearth.com/images/uploads/fisheradfront.jpg
Original sales brochure for Fisher Stoves -(rear of ad)
http://hearth.com/images/uploads/fisheradrear.jpg
More Fisher Stuff:
Article about the start of Fisher: http://hearth.com/images/uploads/fisharticle.jpg
Article in the Eugene, OR paper about one Fisher Factory leaving the town in 1984:
http://hearth.com/images/uploads/fisher_leave_town.png
669
