WV red oak
Dave, I don't know how I missed this thread but WOW......beautiful job, bud! I have to build almost the EXACT same corner cupboard for my living room project, for the audio/video equipment. Only difference will be the doors will have windows in them. I love it. How's about you come down here to Seattle, PA (yeah, it's been raining like HELL down here for the last month, it seems) and build one in my living room? Mrs. Overkill is a great cook, lots of good Christmas cookies, pies and such as we speak!
I love cookies and pie!!:cool:
Reactions: ScotO
That thing turned out sexy as hell.
What are the chances of getting a couple more pics of the door assembly's??
Reactions: ScotO
1st you need a matched set of router bits to make the styles & rails for the door (the door frame)
Then a bit to make the raised panel , center of the door. I have a vertical raised panel bit, dry assemble frame & measure for the raised panel:
WV red oak WV red oak WV red oak
Raised panel for the door: Glue some boards together, cut to size & rout the raised panel profile on the door.
I use the vertical bit since I have a only a 2-1/4 hp router. (But can get horizontal bits to do various profiles.)
Assemble & glue corners of the frame & one side of the raised panel. Clamp corners.
Reactions: Thistle
You definitely want that panel to 'float' in the frame to allow for expansion & contraction during changes in the seasons/humidity.
Excellent work as always Dave! I admire that bench every time you post a pic.>>
Reactions: Eatonpcat
Good point because this will be going into a cabin that does not get 365 day conditioning. In the winter it will go cold-hot-cold-hot.
Old raised panel doors in houses,cabinets,hutches etc (my old house still has 8-9) always left panel unglued for seasonal changes.The wood need to 'breathe'.
I put some glue on one side & pull it into the grove.
Here it's so dry in the winter they rattle :)
Have though about using some clear silicone but never tried it.
Also important to coat both side the same, front got 4 coats & the back got 4 coats.
That way one side don't move more than the other & bow.
I put some glue on one side & pull it into the grove. Here so dry in the winter they rattle :)
Absolutely. You definitely want equal mumber of coats.Outside stuff like decks,certain furniture I dont worry about.Inside things are a different matter.
