There is a house for sale with this. Hot water system but is that it?
Whitenuckler
382
PEI Canada
I was scrolling through some real estate listings and saw this guy has some sort of wood hot water system?
I was reading some other posts and other seem to have a large capacity of hot water and I didn't see any big tank.
  • [Hearth.com] There is a house for sale with this. Hot water system but is that it?
Looks like wood fired hydronic heat...some have storage, some don't.
A system with storage is more gooder.
My father bought and installed a brand new system in a house he built in 1975 or so. It was an combo unit that had an oil burner and a wood compartment. It didn't have a huge volume of water, and it supplied domestic water too. The big mistake he made was to use a masonry chimney and burning chit wood. I think he is still using it, but oil only now. I saw the chimney/stove pipe this guy has and it's a full DW stainless heading out the roof. That unit is going to scare the crap out of home buyers, I bet as they won't even know what to do with it.
After the first energy shortage of the 70's there were lots of boilers like that being made! ( gas went from $.28 cents a gallon to $.50 cents!)
Ya probably Dad wanted to stop paying high oil bills. He bought 7 acres all with mostly hardwood. However, he needed wood right away so we were burning unseasoned wood most of the time. He could never get a year ahead. Also most of it was small, so we didn't split. And that chimney was a creosote nightmare. To clean it we dragged a small fir tree through it. Probably Dad wanted to save money. That's how I learned to use a chainsaw helping him.
Reactions: hobbyheater
had a hot air furnace in my last place pulled it out before I listed it. It is a double wammy, as most folks don't know what or how and then there is the insurance companies. Just like now insurance co. won't even quote if the roof is 20 years old - type doesn't matter composit or steel or cedar shingled.
This is another boiler from the 70's our first boiler. I think its brand name was The Furnace Works, our daughters called it the Pig ! Plumbed in parallel with our oil boiler to take advantage of the DHW coil . Burned 22 cords in the first year and only year of operation before it was replaced ,could see no way of getting ahead to burn dry wood. Had to clean the chimney every week.
This is another boiler from the 70's our first boiler. I think its brand name was The Furnace Works, our daughters called it the Pig ! Plumbed in parallel with our oil boiler to take advantage of the DHW coil . Burned 22 cords in the first year and only year of operation before it was replaced ,could see no way of getting ahead to burn dry wood. Had to clean the chimney every week.View attachment 338626
There is one of those still being used in town here
My guess is there is a storage tank inside of the walled in area in the corner
Oh ya I know. I bought this place, and in the listing it said wood fireplace. Yes I have one, but could not get my insurance without capping the chimney. Too get it certified as it was would mean taking the masonry apart. I just stuck a cheap electric fireplace in the opening and put a pellet stove in the basement. The underwriters have hired a bunch of engineers and they look at every risk now.
OK that must be it as there are pipes going in there, and it was finished with plywood that you can unscrew. You could not circulate all that water just in a unit that size as the water would pass through too quickly
Here a picture of an old wood stove in a farmhouse in east PEI. Looks really old setup to me. Anyone
know what it is? It must gobble wood pretty good. The chimney is brick and here appears to be something
sticking out of the top of the brick on the roof, but the picture is zoomed out. I wonder if they has a steel stove pipe inside
the masonry chimney as well. He must get a lot of heat from the stove pipe as he has metal on the brick.
Its called a Franklin ,yes really goes threw the wood ,most of the heat goes up the chimney !
Hope there are nobody close by it could really smoke clouds !
They are neighbors to my shop...
There is an older CB right in the middle of town that does a good job of pissing off the neighbors. They have it smoldering away everyday.
Those never make friends!
Might be a heat shield...the brick may be attached right to wood framing, so clearance to combustibles rules not met...and yes, those things are forest eaters!
I thought a masonry chimney had to be self supporting? Oh well, I'm thinking this farm house is pretty old. I have no idea why they would be trying to sell with that there. It obviously it can't be used if you want insurance. That is just one more expense for the buyers.
Ah, I see now that is the chimney itself...I didn't blow the picture up before and thought it was just brick laid up to be "fireplace-esque"
Hmm wondering if that is fake brick. Looks like it could be in the pic as it seems like there are thin ends on the corner bricks making me think they are thin brick "Tiles".
No, I'm pretty sure it's real as in the other pictures of the exterior there is a masonry chimney. If you were just going to have a chase and pipe there would be no exterior square masonry chimney. However I think I can see round stove pipe coming out. Maybe in the beginning 1894 or whatever, it was just masonry with some stove pipe to get it from the stove to the chimney. Then maybe after a few chimney fires they upgraded and put the stove pipe in it? I don't think it would fit? I can't get better pic's of the exterior. He probably figured he could heat up that metal and get more heat out of the stove pipe.
I am including the posting
Heating & Cooling
Fireplace Type
Woodstove
Heating Type
Baseboard heaters, Hot Water, Not known, (Oil), (Wood)
I only see one house chimney, but if he has oil, there must be another chimney.
