We installed a Hearthstone Clydesdale wood stove insert about two years ago. I had to remove the wood mantel that was above the fireplace since the heat from the wood stove would be too much.
I made a mantel out of solid cherry and had a local sheet metal company make me a heat shield out of 18gauge brushed stainless steel. It's 38 inches long, and 5 3/4 wide with a 1/2 inch 20 degree bevel in the front. I found some 1/2 inch ceramic stand-offs on ebay, used for high voltage electrical components. Drilled 5 holes and mounted it to the bottom of the mantel. If I did it again, I would probably make it 48 inches long, but this should work fine. Cost me a total of $55 dollars.
Here's some pictures. Hope you like it !
![Stainless Steel heat shield for Mantel Stainless Steel heat shield for Mantel](https://www.hearth.com/talk/data/attachments/164/164697-d33dd36a7a6b3a3d188f9c92f9d844b6.jpg)
![Stainless Steel heat shield for Mantel Stainless Steel heat shield for Mantel](https://www.hearth.com/talk/data/attachments/164/164695-cedfef163672782406de1a691bb8abdf.jpg)
![Stainless Steel heat shield for Mantel Stainless Steel heat shield for Mantel](https://www.hearth.com/talk/data/attachments/164/164696-a7b62fd1c0998f30021b1096c9dd50de.jpg)
