PSG Caddy please help!
Gonna be tough to get secondary burn running wood that wet.
So if you pile up 100 lbs of wood, 29% of that is water...or, by weight, almost 4 gallons! (8.34 per)
Yeah, I don't plan on burning much of it. I just wanted to get a few practice fires in before the end of the heating season.
Do you have a window downstairs you can open to provide some outside air? Just to see if that changes anything.
Yes, I keep the closest window open and for most of the day I had the bulkhead open, too.
But, the blower is definitely still affecting the air inside the firebox. When it comes on hot air pours out of every intake.
What speed is your blower set at ? I run mine on speed 2.
The air you're feeling coming out the front is probably due the gaps in the outer jacket around the door and air intake. I had a similar issue with mine and used high temp rtv to seal it up. It was leaking enough to blow the ashes on the tray below the door around.
Reactions: laynes69
I'm pretty certain that it's not that. It's too much air to be coming from such a small gap. That did cross my mind though so I moved my hands around and I'd say I'm 99% sure it's coming right out of the intakes. I'll try to get a video of it later on when I'm home just using incense or a lighter or something.
Is it still affecting the fire inside the firebox and blowing smoke out the intakes? I'd think if it was pressurizing the firebox like that you'd be filling the basement with smoke pretty fast and the fire would change.
Reactions: SpaceBus
With the stove cold and the door/intake closed, could you remove the stove pipe from the back and turn the blower on? If it were pressurizing the firebox then you should be able to feel the air exiting the back of the stove.
It does still have some affect on the fire inside the box but not blowing smoke out the intakes. When it was doing that I also had the chimney issue. I agree you'd think that it would be sending some smoke into the basement. My only thought is that the chimney is pulling enough that the blower is pushing smoke up the chimney and hot air out the intake.
I should add that the air coming out of the secondary air intakes is much cooler than the air coming out of the primary air intakes. This leads me to believe that the cold return air is making its way into the secondary air passage where it is then splitting off, sending some cool air directly out of the intake and sending the rest of the air into the firebox and forcing hot air out of the primary air intake. That's the only explanation I have for the difference in temperature of the air coming out of the secondary and primary intakes. Also, the air blows harder out of the left side secondary intake, suggesting that the issue is closer to that intake.
I'll be sure to try that as well when I'm troubleshooting later on.
Secondary air path is very long...primary air path is very short...
AHA! It's much easier to feel around for air leakage on a cold stove! The GREAT news is that my firebox is not compromised and everything is good, the bad news is that many of you tried to tell me where the air was coming from and I just didn't get it :(. When you guys suggested it was leaking from the air jacket, I thought you meant from where the green front panel attaches. I did not realize it could be leaking from the gap directly around the door, intake, ash tray, etc. See attached pics. Is it common for the gaps to be that large? The air blows out of them with such velocity that there's no way incoming air is flowing in past the exiting air and making its way into the intakes. That is why I was seeing my fire go out and smoke come out of the intake when I also had the chimney drafting problem. I wanted a video to show how much air is coming out of the gaps but it just blew out any flame and made incense smoke disappear instantly.
FYI, a couple things I did to troubleshoot. With the blower on, pulled off the flue and did not feel any air coming out of the furnace flue. This was also confirmed by the Dwyer mano not showing any pressure changes with the blower on or off. Also lit 4-5 incense sticks inside the firebox and closed the door. If the blower was pumping air into the firebox the smoke would have been blowing every which way, but it was rather calm and slowly made it's way toward the intake (cold chimney puts a slight positive pressure in the box).
The next step is to seal up the gaps. Will the stove get too hot if I seal all of the gaps? Or should I just seal up the ones around the intakes?
The manual requires a minimum duct pressure of 0.2" WC and a maximum of 0.6". I measured mine yesterday at 0.65" with what seemed to be original filters and 0.7" with brand new filters. I know it's higher than recommended but is that a big issue? In theory, it will go up a little when I seal up the stove. I have 3 more floor vents in the second floor that I can open. I could also add an opening to heat the basement, but is the heat loss worth the pressure reduction? This is all with the fan on low.
Thanks again for all the help and advice!
  • PSG Caddy please help!
IMO, that's some pretty darn high SP!! This would also contribute to the excess air being pushed out those small gaps. If you had lower SP (like in the 0.2" range) you'd see a lot less air escaping through those gaps.
Are all your vents open?
Agreed...0.6" doesn't sound right at all...
I have same furnace ( older green model ) that you do and I have zero issues with excessive air coming out through the gaps. My duct pressure is a little over 0.2 though. I'm with @JRHAWK9, I think your high duct pressure is causing some of your issues.
It is hard to tell from your pics, how large is your return air duct ? @brenndatomu please correct me if I am wrong, but I believe your return duct should be sized larger than your trunk line coming out of the furnace. You could take the back cover off of the furnace and run the blower and see if you have the same issue with excess air blowing out of the front.
Yes, at least 10% larger
Get your SP down first...I'd hesitate to plug those gaps since they look intentional...I always wondered if that wasn't the big difference in why the Tundra 1 cracked and the Caddys never did...Tundra doesn't have that "air cooled" front like the Caddys do.
This is my thought as well. If there was a fire in the box and air coming out of the intakes then the chimney is now acting backwards. Pretty much impossible to have a fire in the box and no smoke in the house if the air is coming out of the intakes.
Edit: I replied before reading, I see this part has been figured out.
All the first floor vents are open. I also ran 3 small vents to the second floor that are closed because the space is currently unfinished. I'll try opening them and see how it changes.
Good point.
I doubt return air restriction is the problem since a larger return would only increase pressure on the feed side, right?
In any case, the hot air plenum is the full size of the opening (see my original pics in the first post) but it reduces down to (IIRC) an 8x18 trunk. All of the branches off of that are either 6" or 8" round flexible duct. I'll have to measure when I'm home but they're all insulated so tough to tell. There are 7 of those that I can think of. And then 3 additional 7 or 8" oval ducts going to the second floor that are currently closed.
Open concept house so there is a single return air duct that is probably 14x24 but that is converted to a round duct probably 14 or 16" in diameter before connecting to the return air plenum. That can be seen in the original pics as well.
I didn't really pay much attention to it at the time since I'm not an HVAC guy, but I'm thinking the round flex duct may be a big contributor to the static pressure. Since it isn't smooth and can be easily restricted around bends and what not.
Thats on the supply side?
If so, flex is not recommended for wood heaters...not rated for high enough temperature, and the flow characteristics on it is terrible...flows "much smaller" than its nominal size...
Yep, that's on the supply side. Kind of stuck with it now. I'll take some pictures later.
Perhaps I'll slowly change it over time.
Supply air trunk is 8x20, all the branches are 6" flex. Return air is a 14" round.
I opened the 3 vents to the 2nd floor sand static pressure dropped to just over 0.6" WC. Still lots of air coming out the front.
Next thing I think I'll try is to put a louverred vent on the supply air trunk to relieve the pressure. The lost heat is going to the basement either way but at least this way I'll get more efficient burning.
What kind of filter(s) do you have in? If you go to a higher MERV filter that will lower the CFM output some too...
Reactions: sloeffle
So supply duct is 160 sq inches (probably a bit on the small side) and then that goes into flex line?
Return line is 154 sq inches...which should actually be at least 10% bigger than the supply.
Just FYI, in case you plan to upgrade things at some point...
Reactions: sloeffle
