Hello
Well, since I could not fit another wire in the old 100 Amp Challenger Circuit Panel (Not the best panel we had since the 100 Mains melted one summer! LOL) we decided upon the very needed upgrade! To eliminate the birds nest and add whole house surge protection with a Generator Interlock and outlet, it is a welcome addition. Now the shed has the 30 amp breaker like it should.
See shed electrical
https://www.hearth.com/talk/threads...ld-i-use-10-3-uf-b-or-10-2-uf-b-and-is.76717/
I also wanted to throw in some current meters to see the draw, but that took an extra month to find some that were accurate enough to work!
See current meter finding!
https://www.hearth.com/talk/threads...idential-circuit-panel-will-this-work.134234/
The old meter box and wires along the side of the house had to be changed as well as the circuit panel
The a new Eaton Cutler Hammer panel was installed with nipples to a panel meter box on the upper left side. The current transformers must be installed in the circuit panel box on the 2 mains. A 120v switched outlet with a 120vac to 12vac step down transformer to power the current monitor displays and circuitry on the lower left side.
The 30 Amp generator breaker must be installed in the top right next to the whole house surge protector breakers so the interlock slide works properly.
There is a new ground rod on the outside now so if lightning hits the wires it will not travel into the house! I know it is more needed in Florida where the lightning is more fierce but still good to have here and is also in the new electrical codes!
Pic 1-4 Old Challenger Panel
Pic 5 - Old service head
Pic 6-7 Old meter socket and house wires
Pic 8-9 New outside wires and meter socket with ground rod going into the ground!
See shed electrical
