I'm almost finished installing my Tarm and have a couple simple wiring questions. First, I need to connect my Automag to a transformer and want to make sure I have it right. I assume I connect the red (fuse) wire to the Load/R terminal on the 24v side and the white wire to the NEC/C side. Second, I need to connect the zone valve to the BLT panel I purchased from Bioheat USA. The zone valve has 5 screw terminals. The three that I believe are meaningful are labeled TR/TH, TH and TR. Since I am not using a thermostat, but rather am simply going to the control panel should I just use the TR/TH and TR terminals? Also, does it matter which wires (i.e. red or white) connect to which terminals on the zone valve and BLT terminal strip?
Thanks for your help.
