Zero clearence
Helsasser
1
Ohio
Hello all,, I pulled the sheet metal fireplace out of a zero container. I'd like to put a Buck #74 back in. Do any of you see a problem with this? Clearences around the unit are great that it can be walked around. everything from the zero is still there except the firebox. The old unit was for looks only. Very little heat. Every thing went straight up the flue. And if some body knows= what is the differance between zero insert vs regular insert and mobile home certified vs manufactured home certified inserts.
Well if you are talking about a buck 74zc you will be fine as long as you replace the chimney also.
A zero clearance fireplace is not an insert it is a stand alone unit that is meant to be built into a wall and has very small clearance requirements. An insert can only go into a working wood burning fireplace
