Zero Clearence pipe temperature
lloyd08
7
Ont.
I have a zero clearance fireplace. How can I get a temperature reading on the chimeny pipe ? There is no temperature gauge on the fireplace anywhere. So far we are just keeping the fires fairly small. What is the best method to get a acurate temperature of the fireplace ? Any Suggestions are appreciated.
For the Neat & Glow Northstar I put a magnetic thermometer on the frame of the door. That is the only thing really in direct contact with the firebox to stick anything to. The facia has an air gap behind it on that unit. That's about all I can help you with without knowing what you have.
The fireplace is a Selkirk 2000. It also has gravity vents. Unfortunately there is no blower fans on the unit. The picture on the avatar are of the firplace when we bought the house as you can tell it was not even close to being to code. The gauge on the door is a good idea. Thanks.
Selkirk makes some ZC EPA boxes.
Why are you burning a fireplace that is obviously not to code? Do you have an installation manual? Were the fans originally required and now removed? Pyrolysis could lead to a house fire. Why not re-install it to proper safety codes?
Your avatar looks like a non-EPA prefab fireplace. No real reason to measure the temp if that's the case, as you probably don't have any way to control it anyway.
On my Ultima EPA ZC I put the thermometer on the stub of pipe behind the top louver. Unfortunately to see it you need to put your face right up to the louver and peer between the slats. There is really no spot on the face of the Ultima that would give a useful reading.
Seaken: I didn't have a fire in it until it was brought up to code. When we bought the house it wasn't to code. We have made all the necessary changes and have it WETT certified. No I don't have a manual. I have looked on Selkirks site and have found nothing. Instead I have read as much as I can from this site. As for the fans there were none originally. The installer said that I could have some put in.
Sorry to be a pest. I do not wish to irritate you. But how did you manage to bring it up to code without the owners manual or installation instructions from the manufacturer? In all cases with factory built fireplaces the manufacturer's installation instructions is the code. These are listed products and the listing establishes what is code. Without those instructions present to refer to I fail to see how you could determine the fireplace is now up to code. Accepting a local inspector's word for it does not make it safe. WETT does not determine the codes. The manufacturer's laboratory listing determines the code. Get that manual.
Sean
seaken said:
...But how did you manage to bring it up to code without the owners manual or installation instructions from the manufacturer?...
Ask that WETT certified hearth professional that he hired Sean. Not him. :coolsmirk:
BB - Ducking under his desk.
Yes, exactly! Shouldn't the WETT guy know he needs the owners manual?
Sean
I have the manual. Post#11. Thanks Leelli !!
I knew the fireplace wasn't to code when we were looking to buy the house so I hired a certified Technician to tell me what needed to be done to bring the fireplace to code. They explained everything that needed to be done and why. This was at my request no one Else's. I did the work I was comfortable with and they did the rest. They install these for a living so they had better know the codes.
If it needed to much work I would have ripped it out and planted flowers in it. (Seriously it was going beside the spruce tree in the front yard.)
Thanks for your interest.
Don.
