You know life is good when ............................
pen
There are some who call me...mod.
Staff member
7,968
N.E. Penna
your kitchen looks like this, and you are not supporting foreign oil.
:coolsmile:
What are some of your inside / outside readings?
My stove is in the basement and this is on the first floor.
pen
[Hearth.com] You know life is good when ............................
13.6 outside.
76.1 about 10 feet from the stove. The stove isn't really working hard at the moment. My kitchen is running about 65. If I turned the fan on in there it would be a few degrees warmer. The rest of the house is held about 60 via natural gas. I don't burn foreign oil either. (Although I think we produce most of our own heating oil.)
Matt
19* F outside, 85* in the living room with the stove, ~75* upstairs in the bedrooms, ~65* downstairs in the family room.
-SF
It's not the size of the firebox.... FWIW, it is about 70* in the upstairs rooms.
  • [Hearth.com] You know life is good when ............................
This morning it was 10 outside and 82 in the living room the stove is in the kitchen. ~75 up stairs in the kids bedrooms.
10 degrees in Missouri? Ouch! We haven't gotten below 20 and the forecast is for 56 tomorrow :(
Ken
southern Ohio
This AM, 4* outside and 80 in stove room. 62* in bedroom, perfect to sleep. Wind chill last night at a chimney fire was -20, wind gusting to 50mph. Saved the house, no extension into the walls. Be safe.
Ed
14 this morning, wind chills in the low single digits overnight. Comfortable 69 in the living room when I woke up at 5, 78 when I left for work at 6:30. My wife loves waking up to a toasty house.
I have better wood, better insulation and a better system this year for overnight burns. The last couple years, I would have woken up to a living room temp around 62 in this kind of weather.
Life is indeed good.
I had 11 degrees outside at 7:00 this morning,it was 61 in the kitchen,dining,living room area of the house,it usually only takes a couple hours to get it up to 68,as long as the wind isn't blowing.It was 66 in the front room where the upstairs woodburner is and about the same in the basement.
:coolsmile:
pen
bring that humidity up and it will fill even better!
smokinj said:
:coolsmile:
pen
That unit is terribly inaccurate for humidity.
I have a drybulb / wet-bulb hygrometer that I use to keep the moisture about 45%. However, I don't really need it. I can tell if I am below 40% when the wife gets a nosebleed, and above 50% when moisture collects at the bottom of my windows.
pen
Had 4 F outside this morning and 73 inside at 6AM after an overnight burn.
Heating with natural gas heat in 2006 - averaged $525/mo. and temp inside was 63 to keep $ down
Heating only with 1 kerosene heater and no natural gas in 2007 - averaged $410/mo and temp inside = freaking cold!
Heating only with wood pellets in 2008 - $250 (50 bags) so far out of our total bags - average temp inside a balmy 73 (yeah baby!)
