I just purchased a Enviro EF3 about 4 months ago on Craigslist, couldn't pass it up when it was listed for $295. Drove 2 1/2 hours to pick it up, and even negotiated down to $250.
I've spent those last 4 months cleaning, sanding and re-painting my new treasure. When I finally got it all shiny (well, fresh flat black main body, and metallic gray door to cover the very tarnished gold trim door) I had to start looking for information on venting. I did a lot of googling, spent lots of time checking and re checking and measuring, all of my walls and ceiling 3-4 times a night. Everytime I spent anytime googling or searching through the Internet, I always seemed to end up here.
I can't believe how much help this website was for me. After building a hearth, another idea I got from this forum, I got my piping (check jet.com if you already know what parts you need, I saved over $100 compared to my local hardware store) I gave my local government about $130, for a piece of paper that said I could install something in my own house, and got to work. I put my new hearth in place and after some grunting got my new precious into her new home. After a few hours of lining up my pipe and making sure everything was sealed and ready I took my helper out for a beer. I was so excited, finally got my new pellet stove in!
I made and appointment for the inspector and was ready to burn, or so I thought. The inspector came out and started looking around.... 5 of the most awkward minutes I've ever been involved with. He finally spoke and said, "well you know this is all wrong right?" I all but fell over, how did I spend 4 months on this and still mess something up? I asked him what he meant, and he told me it was because I didn't have the minimum requirement for clearance to a combustible wall. I know I measured everything Two and three times before I finished my install. He told me the minimum clearance was 6". After I pulled up some information from the vent pipe company to show him that the correct clearance was 1." I was shocked to see that he had pulled up something very similar and it was on hearth.com. Even the inspector used this site, awesome!
Now that I have my certificate in hand I started my new stove, only to find out that I have an issue.
I spent days pulling different components out to make sure things were clean. I decided to look on here again to see if anyone had the same issue I had (fire seems to die after random period of time, turns out it only died after the dial-a-fire gets adjusted). Once again you guys saved me from having to turn to a more expensive option, either replacing part after part to eliminate the possible issues, or calling a stove repair professional like my wife wanted me to. I ended up on the sticky on this forum in the service manual for my enviro. Used the service manual to troubleshoot until I verified the problem and I will be going to purchase the replacement part tomorrow. Hopefully that will fix my issue, but if it doesn't, I know this forum will be here to help me again.
So I apologize for the very long wind version of this but....
THANK YOU
I joined the forum strictly to write this post, but maybe something I learned along the way will help someone else, and I will try to keep an eye out to see if I can help, and try to repay all of the help I got.
THANK YOU
