This trick is basically for cleaning the pipe and
works especially well on a vertical length:
Take a small ballpeen hammer and tap the pipe
about a dozen times above your cleanout T.
Now ya don't need to smack it so hard that
you leave a mark, just some good firm taps
and be prepared because loads of ash will drop.
I usually remove the cleanout T cap, position the
vac nozzle underneath, then start tapping on as much of
the vertical vent as you can reach. Follow up by running
a brush up the vent a few times, but the tapping easily removes
80% of the crud.
I've got 15 ft of vertical pipe running up inside the chimney
and this method works awesome. Been cleaning it this way
since day one.
80% of the crud.
since day one.
