Just got off the phone with a helpful gentleman at Rhino Linings Industrial. I described the needs of a storage tank liner, including the operating temperature range, the ability to withstand deflection of the tank walls, and the need for chemical stability to avoid corroding the heat exchangers, or killing the residents with some gas.
Seems they have a product which is well-suited to the application. According to the gentleman I talked to, the 175 is listed as a conservative number, and the product will easily withstand regular service up to 185-190, and won't fail during a boil-over situation, as long as that is not a regular occurrence.
Only issue is the cost, which is not low, at least in this area. I assume it will vary depending on where you are located, and who the local applicator is, since Rhino doesn't set pricing. I'm going to keep checking around and see if any of the mobile truck bedliner applicators can order the Hi-Chem 65D-PW and apply it, or if their equipment or contract doesn't allow them to do so (not sure if the industrial line is available to them, or if it requires special equipment).
Joe
Joe
