2006 Englander PDVC-25
Problem: No Upper Auger
Went to fire up the stove, and found top auger to not be working. As soon as hopper was empty, auger started spinning. Since it still had the original motors, I just decided to do a 'refresh'. Ordered 2 new motors, and new bearings. Replaced the motors, and it fired up just fine.
Noticed that my room air blower was very weak, so after about a 2 hour burn, I shut it down.
Today, I pulled the room air blower out and cleaned it. (It was nasty! And fully explains why it was blowing weak)
Reassembled everything, and now I am back to no top auger.
I have:
Cleaned Everything
Checked, and bypased the Vac Switch.
Swapped motor leads. (Both motors good, both augers spinning with no binding)
Checked, double checked, and triple checked every connection on the board.
Factory Reset procedure
Checked Mode, Confirmed Mode D
Diag Mode. Confirmed no Top Auger control in Diag.
I am assuming the worst ... its the board. I just wanted to make sure there is nothing else I can do, check, or verify before I spend $300+
I have:
Cleaned Everything
