Man this is a big bad boy....
Stable striking surface of a polymer with a steel ring.
Dampens vibration at impact, thereby reducing the risk of cracks in the material.
The wide blade on the trunks of trees and removal of lateral branches.
Wide, rounded surfaces are easier to use than the wedges.
In particular, a stable core of glass fibers.
Comfortable and anti-slip grip.
Rubber - Protects Topor and reduces vibration.
Length 90 cm
Weight 3900 g
The X27
Fiskars Splitting Axe X27 stop at a block without any major problems with it can sting even the largest pieces of wood.
Directly I destined for processing large quantities of wood such as the long winter season.
With this you ax for splitting wood becomes entertainment.
With its unique design saves you a lot of strength and it is possible to work with long periods of time without undue fatigue, back and arms.
Technical parameters:
Overall length: 92 cm
Total weight: 2600 g
the X25
Product Dimensions:
Weight (kg): 2,430
Height (cm): 72.00
Length 90 cm
Weight 3900 g
The X27
the X25
Product Dimensions:
Weight (kg): 2,430
Height (cm): 72.00
