The issue I am having is that the stove cement around my interior single wall pipe cracks and I can feel cool air when putting my fingers close to the seams in the pipe. I have re-sealed and have the same result. I was looking at the product listed below and was wondering what your thoughts are regarding simply wrapping it only around the seams.
http://www.adlinsulflex.com/heat-resistant-tapes/silicaflex-tape-ab
A low cost, convenient, field-installable solution to some of the most demanding high temperature problems.
A health conscious alternative to asbestos
Silicaflex™ Tape AB is a slit silica tape constructed from 96% pure SiO2 silica fiber, coated one side with a pressure sensitive adhesive backing that facilitates installation. The adhesive decomposes at high temperatures, leaving a perfectly tape-wrapped hose, cable or pipe.
Designed for severe heat environments
Suitable for use at 1800°F (982°C), and able to withstand short term exposure up to 3000°F (1650°C), Silicaflex Tape AB sets the standard for flexibility and minimum lineal shrinkage under high heat conditions.
Durability is further enhanced with a proprietary hydro-carbon coating, giving Silicaflex™ Tape AB unmatched abrasion resistance and tensile strength.
